dorkus
- Oct 9, 2002
i just got my Muse today - took a little under 3 weeks from my original order date, which seems relatively reasonable.
out of the box, there were a few things that didn't look so hot. the front panel has a smudge on one of the markings, as if the ink didn't dry before they handled it. there were also a lot of fingerprints on the faceplate, as if the unit was used. also the terminations are of inferior quality as people mentioned - the "gold-plated" connectors barely look like they have a gold flash on them and are already tarnished looking. the USB connector is extremely loose and doesn't seat the plug all the way. and the unit has no feet at all, allowing bare metal edges to contact whatever it's on.
i powered it up and plugged a pair of headphones in. the first thing i noticed was a buzzing noise - turns out it was a variable speed fan i had on in my bedroom. it probably has a noisy triac, and i imagine the stock Muse power supply (wall wart) is very poorly filtered. i turned off the fan and the noise subsided. then i tried hooking it up to my iMac via USB. i got sound, however there is a ton of clipping at even a very low volume level. this leads me to suspect a reversed part or other assembly issue. i'll have to take it apart tomorrow and check out what's going on inside.
so, first impressions are pretty piss poor, though for the $129 or whatever i paid i suppose it's to be expected. i have a lot of leftover parts and tools from my DIY days, so i don't mind a fixer-upper... just would have been nice to have some semblance of quality control on these things. i'm going to file a complaint with the seller now.
