Uncompressed is the original untampered with
The original is also often FLAC that is delivered to the label/publisher. Many of these companies won't be keeping WAV copies when there's no reason to, they're not going to just store many petabytes of extra data if they don't need to.
Yes, MQA "folding data into into 44.1khz data" was always a lie, and actually did get proven by hardware meters which people bought to prove it.
Technically this part wasn't an outright lie. It DID store some of the 22.05-44.1khz info and put it back during the core decode, the issue was that they claimed that this process was lossless when it was not and they were not clear about the additional drawbacks/compromises that their process incurred. Also the fact that a huge amount of content was 44.1khz originally but converted to MQA purely for marketing reasons when there was literally no reason to do so and would only cause negative effects.
Additionally whilst the core decode (which could be done by the player) did restore some of that info, the 'renderer' part that was baked into devices was in reality just a fixed upsampling filter that did not do any of the folding stuff, hence why they never let any of those devices ever include a digital output else people would be able to easily check that.
Are you still positive that MQA is the same?
No one is making the same argument in regards to MQA. Lossy compression methods such as MQA and MP3 are a completely different debate to lossless compression.
Especially if you buy gear with an extra chip for everything to pass through that the original doesn't need?
MQA didn't require an additional chip to process. The 'renderer' just ran on the XMOS chip that many devices already had, hence why a lot of devices got MQA support retroactively. It required a license paid to MQA, but didn't require extra hardware.
The 'full decoder' option required the use of one of the more expensive XMOS chips but this wasn't an extra piece of hardware that wasn't there already.
Will this thread get locked if I am anti-MQA?
No, there are many of us which are quite firmly against MQA (I was the one that published the test tracks on Tidal and made the original video btw), but most of the discussions had have been fairly civil and constructive, unlike what has happened over the last couple pages here. The issue isn't your position, it's that you're unwilling to listen to what anyone is saying and are responding in a quite hostile manner rather than trying to argue or explain your point with sound reasoning.
Why do you even subscribe to a streaming service? YouTube already won't tell you the 90% you're missing as mp3 versions.
Because we do want lossless quality. Again, the argument of MP3 vs lossless is entirely separate from the FLAC vs WAV debate.
FLAC and WAV both contain literally identical information bit for bit. FLAC is just a more efficient way of storing it. MP3 loses information/data to save more space and cannot be decoded/restored to retrieve the same original information. No one here is arguing that MP3 and FLAC are identical.
