pokipoki
- Mar 30, 2005
Open the .avi in QT7 (Mac OS X), press CMD-I to "Get Info", confirm if you see DX50?
For XviD movies :
- install #1 *OR* (#2 + #3)
For DivX movies :
- install #3
For movies containing AC3 tracks :
- install #4
Example on my Mac, in order to play all Xvid/Divx/AC3/MP3 movies, I install #1, #3 and #4.
DivX6 is not yet available for Mac OS X, download & use Divx 5.2.1. The seeking somewhere issue with DivX is probably due to lack of b-frames/key frame support.
It will still search & play if you wait a while longer. I would pause movie, seek, wait for frame to appear, then press play again.
Use VLC for .mkv & .ogg movies on a Mac.
If you can play Xvid/Divx movies but encounter artifacts/blockiness, temporarily remove either Xvid or Divx component & test alternately. One of them is causing the issue.
For XviD movies :
For DivX movies :
- install #3
- install #4
