It has been awhile so I am going from memory of 2 years ago. I also, did not put much effort into finding the ideal set up for the Aria. So, please take that into consideration. The Aria was too splashy in the upper mids and lower treble. The bass had more distortion than I prefer. Male vocals were weak and female vocals were brash.
I consider the Kato a big upgrade from the Aria. But, it also took some time, going balanced, and tip rolling to get the Kato as good as it is, IMO. I don't know what the ceiling is for the Aria.
I was recommended Chu 2 as a low priced daily driver iem for on the go with my smartphone, but the one on Amazon doesn't come with a mic. @MOONDROP Can you put them up on Amazon with a mic?
Liking my Space Travels, enough that they replaced my wired iems for when I sometimes listen to music as I go to sleep. Got them in the dark flavour.
However, one issue I had was with the eartips, none of them worked for me and I had to pick something out of my random-iem-stuff-box to get it to work. Don't think my ears are particularly unusual though, as I never had this problem before - one of the stock eartip sets would usually do it for me just fine for other iems.
Also just ordered Chu II, I just had to do it given the Black Friday sale prices.
The space travel is surprisingly decent for tws for $20. Mine arrived last week. I didn’t have high expectations for such a budget set, but was pleasantly surprised.
Pros:
Built like a tank
Decent ergonomics
Modular cable to increase source pairing options
Relatively easy to drive
Fast, textured and clean bass; good sub-bass extension
Transparent and clean midrange
Natural timbre
Solid technicalities for a single DD Cons:
Dearth of eartip choices
Below average isolation
Borderline shouty upper midrange
Diminishing returns for existing owners of the Aria family, is a solid but sidegrade single DD in the big scheme of things
Graphs versus other Arias, 8 kHz is a coupler peak:
Pros:
Built like a tank
Decent ergonomics
Natural timbre
I like the Aria Snow, but would like a bit more v-shape, and I looks like the Aria e might delivery exactly that.
Compared to the Snow, how are the technical capabilities of the Aria 2?
Check out the Simgot EA1000. It is one of the most resolving $200 sets I've heard, has a passive radiator to add some sub-bass heft.
Has 3 tuning nozzles to change the sonics, but is a bit bright if you are treble sensitive.
