redrol
I agreed the KPE is highly detailed in a great way. The A8 on the other hand takes that up a few notches, maybe 10. lol
Awesome suggestion! Will try that today. I will put some on a Q-tip and apply to the screen while holding the IEM nozzle down and keeping it that way so no liquid pours into the IEM. Thank you again for the suggestion!Hydrogen peroxide can dissolve earwax. I wouldn't dip the IEM in it but maybe a drop on the screen followed by lightly damping up the drop after it sits for awhile might help.
I hope you've moved on to something better but you can always buy them back again. I would miss mine and their hours of daily musical bliss immensely.i sold my KP, i hope that no regret is waiting for me after couple of weeks
I would slightly dip the tip in 99% isopropyl alcohol and let them dry out a few times. The 99% will evaporate quickly.Any suggestions for cleaning the KPE grills? I think I ha a thin sheen of ear wax blocking the small grill opening. I have read problems with removing them and trying to put those back, so haven’t tried that. I have them in with silica desiccant to try to dry them out. Any suggestions would be appreciated.
Will try that as well - thanks!I would slightly dip the tip in 99% isopropyl alcohol and let them dry out a few times. The 99% will evaporate quickly.
KxxS will be there next month
yes, i will keep an eye on that one for sureKxxS will be there next month waiting for you.
