imackler
- Nov 17, 2008
Does Monster's lifetime warranty mean one replacement? I've thought about Monster but have been scared away by talk of quality control...
Quote:Does Monster's lifetime warranty mean one replacement? I've thought about Monster but have been scared away by talk of quality control...
one time replacement if you broke it, lifetime coverage against defects, and no, it's not within two months or two years, it's until you die, or the phones change ownership. also, to clarify the two month part in the booklet, you must report a defect within two months of one arrising, and send it in within 45 days before the RMA number expires, purdy much, 50 years later, when the left ear piece gives out, you have two report it within two months of the defect and send it in
Let's just hope that Monster is still in business half a century later.
yes, the separation of the housing on the turbines are more common than the ie8's nozzle. My own regular turbine has the same issue right out of the box and the right has a 20% decrease in volume comparing to the left. As of now, Im thinking about upgrading to IE8. However, most people thinks that the copper will have a better tone than the IE8. I just don't know if I should sacrifice IE8's comfort for copper's sound. What do you guys think.
Quote:yes, the separation of the housing on the turbines are more common than the ie8's nozzle. My own regular turbine has the same issue right out of the box and the right has a 20% decrease in volume comparing to the left. As of now, Im thinking about upgrading to IE8. However, most people thinks that the copper will have a better tone than the IE8. I just don't know if I should sacrifice IE8's comfort for copper's sound. What do you guys think.
Glad you could fine the IE 8 comfortable. I can't even wear the square housing somehow.
Quote:Quote:yes, the separation of the housing on the turbines are more common than the ie8's nozzle. My own regular turbine has the same issue right out of the box and the right has a 20% decrease in volume comparing to the left. As of now, Im thinking about upgrading to IE8. However, most people thinks that the copper will have a better tone than the IE8. I just don't know if I should sacrifice IE8's comfort for copper's sound. What do you guys think.
I don't have the IE8, but I do have the IE7, which has the best fit out of all my earphones including TF10, X10, turbine, superfi 5, and superfi 5eb. So I assume the IE8 will fit me pretty well too. I also like the exchangeable cable on the ie8 because my Ie7 broke because of the cable . I sleep with my earphones thereby putting a lot of stress on the cable and I bet the MTPC won't last that long.
