Finally another head-fier with an Exogal Comet dac! These things are ridiculously underrated amongst the head-fi community and I don’t understand why. Anyway, unlike most dacs, the Exogal outputs the same Vrms from its balanced and single-ended outputs, (most dacs have double the Vrms from their balanced output) while the LP uses a phase-splitter at its se input to amplify the incoming signal. So the Liquid Platinum’s inputs are designed to equalize an output power discrepancy that the Exogal doesn’t have. Thus when I use a single-ended chain from the Exogal to the LP it is twice as loud as going balanced from the dac to the amp. (This is all in reference to using the balanced headphone output on the LP btw.) I also preferred to use the se input on the LP from my Exogal—I found more play on the volume knob and a livelier sound from the amp. So long story short, it’s not your cables, it’s this dac and amp combo running balanced that present unique issues. I’d love to try the LP with a different balanced dac—like the Gumby I used to have—to take better advantage of the fully balanced chain, but not enough to get rid of my Exogal Comet anytime soon!I actually like this amp better using rcas between my dac and amp. Dac is an Exogal. Maybe I need better cabling as using Kimber Hero in balanced and quite honestly disappointing - dull and closed in sounding. Rcas comparing to are fairly inexpensive Dueland interconnects but bring back the light and dynamics to music.
Have been using balanced headphone cable - made a good upgrade over stock headphone cable (ZMF)
So what balanced cables work well for you?
Monoprice Monolith Liquid Platinum - By Alex Cavalli
- Thread starter ufospls2
hemtmaker
- May 25, 2013
Nice setup! Is this the multibit versionHappy Saturday!
My Alpha Prime and I, are getting reacquainted, with the Gumby and LP combo. Love me some tube glow!
Thanks! Yes, it is the Gungnir Multibit. I use an Eitr to connect my ipad to DAC.Nice setup! Is this the multibit version
Any other tubes recommended that don't break the bank( < $100 Pr), but have great detail, expensive soundstage and not too warm, even slightly bright? I have the Gold Lions, while an improvement they are not quite there. I wish I could find the Brimar's domestically, as I will not have enough time to import them before I have to decided whether to keep this amp.
- Jan 15, 2015
Brimar tubes are warm. Many (myself included) love it, but since you're looking for non-warm tubes - I suggest you do not even consider BrimarAny other tubes recommended that don't break the bank( < $100 Pr), but have great detail, expensive soundstage and not too warm, even slightly bright? I have the Gold Lions, while an improvement they are not quite there. I wish I could find the Brimar's domestically, as I will not have enough time to import them before I have to decided whether to keep this amp.
TK16
Have a pair of Mullard Mitcham E88CC in the classifieds here, but they are warm tubes like the Brimar CV2492 and not your desired sound sig. If your open to using socket savers and 12A*7 to ECC88 adapters the Telefunken ECC82 and Siemens ECC82 fit your description And are in my signature. If your not into the adapter scene that's cool too. I can make some recommendations on 6DJ8 variants if you want?Any other tubes recommended that don't break the bank( < $100 Pr), but have great detail, expensive soundstage and not too warm, even slightly bright? I have the Gold Lions, while an improvement they are not quite there. I wish I could find the Brimar's domestically, as I will not have enough time to import them before I have to decided whether to keep this amp.
LCMusicLover
I think this is relative. My Brimar CV-2492s are not as warm as my Siemens E88CCs or CCa tubes. The Brimar pair better with my Empyrean, which appreciate the Siemens warmth less compared with my HEKv2, and especially my Utopia and Auteur. Ether 2 are pretty happy either way.Brimar tubes are warm. Many (myself included) love it, but since you're looking for non-warm tubes - I suggest you do not even consider Brimar
There are a couple different Brimar CV2492 versions out there as well. One is real, and the other is Russian made, so it depends on that as well.I think this is relative. My Brimar CV-2492s are not as warm as my Siemens E88CCs or CCa tubes. The Brimar pair better with my Empyrean, which appreciate the Siemens warmth less compared with my HEKv2, and especially my Utopia and Auteur. Ether 2 are pretty happy either way.
TK16
Yeah those British CV2492 have "KB/AD" on the paint. Rochester iirc?There are a couple different Brimar CV2492 versions out there as well. One is real, and the other is Russian made, so it depends on that as well.
The KB/AD is a good indicator, that they are the good ones. I have seen Mullard and Russian's with the CV2492, but they did not have the KB/AD.Yeah those British CV2492 have "KB/AD" on the paint. Rochester iirc?
LCMusicLover
I think I got the 'right' ones. From eBay seller yellowlorryredlorry. This auction:There are a couple different Brimar CV2492 versions out there as well. One is real, and the other is Russian made, so it depends on that as well.
https://www.ebay.com/itm/2-CCa-E88C...m43663.l10137&nordt=true&rt=nc&orig_cvip=true
Anyway, my impressions are based on those tubes.
Yep! Those are the good ones. I put those same tubes in, and have not even thought about rolling anything else. I love how they are smooth, but detailed.I think I got the 'right' ones. From eBay seller yellowlorryredlorry. This auction:
Phantaminum
Look for something like the Tungsram 6922. You can purchase a pair off eBay for that price. Be sure to buy from a seller that allows you to return tubes in case you run into any issues.
nwavesailor
- Nov 14, 2009
It looks like this UK based E-bay seller no longer has these Brimar CCa listed.
LCMusicLover
The auction description says CCa, but the tubes say CV-2492.It looks like this UK based E-bay seller no longer has these Brimar CCa listed.
And you just need to keep watching. He puts a pair every couple of weeks (or less). But he doesn't have a single auction listing all his stock -- as in 'xx available'.
GLTY
