Monoprice Monolith Liquid Platinum - By Alex Cavalli
Jul 22, 2019 at 5:46 PM Post #2,283 of 5,148
Jul 22, 2019 at 6:29 PM Post #2,284 of 5,148
Have a pair of Mullard Mitcham E88CC in the classifieds here, but they are warm tubes like the Brimar CV2492 and not your desired sound sig. If your open to using socket savers and 12A*7 to ECC88 adapters the Telefunken ECC82 and Siemens ECC82 fit your description And are in my signature. If your not into the adapter scene that's cool too. I can make some recommendations on 6DJ8 variants if you want?
Thanks. What are some variants I can directly use.....and not have to import? Don't want to spend a lot on adapters and tubes, at least till I know I want to keep it. Just looking for tubes a little more neutral sounding. May not have time to import before I decide whether the amp is for me or not. Have about 20 days left.
Jul 22, 2019 at 6:49 PM Post #2,285 of 5,148
Neutralish sounding Siemens E88CC grey shields or Telefunken E88CC, these are bit warmer than the Siemens with the Siemens having more detail. If those are too expensive you can try the ECC88 variants as they will be cheaper than the E88CC usually.
Jul 22, 2019 at 6:54 PM Post #2,286 of 5,148
I have seen some Matsushita's 7DJB's around and have been described as extended on the top and bottom. Any good?
Jul 25, 2019 at 1:27 PM Post #2,288 of 5,148
Hi
I am wondering how exactly does this amp work?
are the tubes jusk an input buffers or do they actually amplify the signal ?
Jul 28, 2019 at 7:09 PM Post #2,289 of 5,148
This might be a noob question, but I was looking at the balanced power output on this unit.
33Ω 6.62 watts
56Ω 4.21 watts
150Ω 1.74 watts
300Ω 0.91 watts
But it also says on the webstite "the Platinum features fully balanced/differential amplification with 3.6 watts per channel (balanced) into 50R load".
what exactly is the RMS power output?
For those who have NFB11 and LP, would you say LP is a noticeable upgrade pairing with HD600 series balanced?
Jul 30, 2019 at 4:42 PM Post #2,291 of 5,148
Has anyone been able to compare the LP to the WA6 (non-SE)?
I have both and IMHO they are quite different. The WA6 (I have the original, not the current V2) is a very lush-sounding tube amp and tube rolling can change the sound quite a bit. The LP has the trademark liquid Cavalli midrange but is more neutral-sounding to my ears.
Jul 30, 2019 at 4:46 PM Post #2,292 of 5,148
Which would you say has greater bass impact?
Jul 31, 2019 at 6:20 AM Post #2,294 of 5,148
The LP, especially using the balanced output.
I thought that might be the answer, as I really can't imagine the bass hitting any harder, than with the LP and the right tubes. The bass just explodes out of nowhere!
Jul 31, 2019 at 7:25 AM Post #2,295 of 5,148
I see that you also have the BHC w/SB... how would that compare to the LP?
