humblesquad
- Oct 26, 2015
Will Liquid Platinum be sold on Amazon.com? International shipping fee is significantly cheaper on there than Monoprice.com.
Workin' on that for ya.
Can't wait your review (especially vs Liquid Crimson, and Liquid Carbon in your memory)
Can't wait for this review... Any possible teasers, spoilers, just to give us a little taste of what is to come?
PS. I posted the above before seeing your last post, which describes exactly what I meant by "teaser"...
One thing I would like to know is to what extent the balanced topology of this iteration enhances or changes its sound vis-à-vis that of the Crimson, which wasn't a genuinely balanced amp. If you can comment on that, the gesture will be really appreciated.
Not sure about this, but the Liquid Platinum certainly looks like a unit that would benefit from the use of an external power supply unit... Does anyone know of a good power supply of 36 volts, 1.5A specs that might match and optimize the sq of the platinum?
I don't know if being balanced changes it that much, per se. There are other factors in the design that will play a larger role in any sonic changes, depending on the headphone. That being said, they sound pretty similar.
I agree that whether balanced make any sonic difference might depend on different factors, particularly the headphone. At any rate, in asking about the difference which "balanced" might make,. I did not mean to disparage the sound of the original Crimson, which had an almost legendary reputation among some headfiers for its sound quality. If the Platinum winds up sounding as good as the Crimson, I will not complain at all, especially given that the Platinum's price will be about a fourth of that of the Crimson.
I suspect you are right about this. Make no mistake, it definitely sounds really good with the SMPS, but I have a feeling it could scale to an even higher level with a linear PSU.
I don't think that would work. The iPower only goes to 15V, but the LP needs 36V.I'm kinda hoping that we could put a group buy into iFi for one of their iPower SMPSs. Active filtering might be a nice cost effective performance improvement that matches the pricing & size of this amp.
Unless I'm mis-reading the specs of one or the other?
