Liquid Platinum vs Liquid Gold X
Since I’m fortunate enough to own both the Monoprice Cavalli Liquid Platinum and the new Liquid Gold X some folks have asked for a comparison between the two. I was finally able to spend some time with both amps side by side last weekend and here are my impressions.
The TL; DR version is that the differences between the two amps are very small.
The playback chain used was a Windows 10 laptop running J River Media Center 27 – Bifrost Multibit – distribution amplifier – Liquid Platinum/Liquid Gold X. The Liquid Platinum is running vintage Amperex 6922 tubes.
First, the single-ended output using the ZMF Aeolus. The two amps sound very similar. The Liquid Platinum has a bit more weight and body in the lower midrange and a bit more subdued treble, but this may be due to the tubes that I use. Would I be able to tell the amps a part in a blind test? Probably not.
Next, the balanced output using the Audeze LCD-2. Again, the amps sound very similar. The treble on the Liquid Gold X is a little bit smoother and cleaner, but the differences are again small.
Conclusion? I prefer the single-ended output on the Liquid Platinum and the balanced output on the Liquid Gold X, but like I said the differences are small and I could live with either amp on a permanent basis. I doubt that I would be able to tell the amps apart in a blind test, or even an A/B/X test. Having said that, I really like the way the Aeolus sounds with the Liquid Platinum and the way the LCD-2 sounds with the Liquid Gold X. They are both great amps.
So, should you buy both? Honestly there is no need to, since the amps sound very similar (and very good) and the Liquid Platinum is already an excellent amplifier. In my case, I’ve lusted after a Liquid Gold since I heard the original amp at a CanJam several years ago, and thanks to the Cavalli/Monoprice cooperation I now finally own one, so I’m happy with both amps and I plan to keep both of them.
Is there any point in upgrading from the Liquid Platinum to the Liquid Gold X? I would say no, unless you’re tired of tubes and want a solid-state amp, or you prefer an amp with a built-in DAC. YMMV, as always.
