Random Lunatic
- Jan 9, 2017
Thank you for giving a snippet of what its like!Having bought this amp on the day it was released it’s time to share some further impressions.
There’s been some discussion on this thread about the differences between the single-ended and balanced outputs. I definitely prefer the balanced output. It’s not that the single-ended output sounds bad, but to my ears the treble is a bit less smooth and clean on the single-ended output. Depending on the track and headphones that I listen to I sometimes find that the treble on the single-ended output bothers me a bit. I’m very treble-sensitive, so YMMV here. This is a different experience than with my Liquid Carbon and Liquid Platinum amps, where I prefer the single-ended output for most headphones. So, if you’re considering the Liquid Gold X you owe it to yourself to invest in balanced cables for your headphones. I’m not into cables so I just buy cheap balanced cables, but how much you want to spend is up to you.
I’ve also found that while the Liquid Gold X isn’t a panacea that makes all headphones sound good, with the right headphones it sounds spectacular. My MrSpeakers Aeon Flow Open and Closed (1st generation) and Audeze LCD-2 sound fantastic with this amp. Especially the LCD-2 sounds better than I’ve heard it with any other amp that I have. I’ve often heard a bit of treble edge on the LCD-2 that bothered me, but that’s gone when I use it with the Liquid Gold X using the balanced output. Well done!
The balanced vs. single end is simply due to both the Gold and Platinum's architecture being inherently balanced, so they really aren't meant to be used single ended, theoretically, its just there for convenience.
