Chastity
- Aug 24, 2002
I don't know why you scooped the 1K-2KHz on the first one, but I kind of like the 2nd one. And I don't use PEACE, just EQ APO, but these work fine as is. Saved me from doing a hand-tooled PEQ from the FR charts.These wouldn't fit but they're the type I'm looking for. I'm hoping to find some velour & some perforated pads (+ full leather) but so far I've found nothing on Aliexpress with the same dimensions. The Goldplanar 850 came with a full leather and perforated hybrid pads, a reviewer said they preferred the perforated more. I imagine they'd be same dimensions as the Goldplanar 1200 but they use velcro pads(?) whereas these don't.
Anyway, I made some EQs for the AMT using the Goldplanar 850 frequency response. I'm hoping to making more later. You can import the files in PeaceAPO
AMT EQ 1:
Code:Preamp: -12 dB Filter 1: ON PK Fc 20 Hz Gain 3.0 dB Q 0.700 Filter 2: ON LSC Fc 90 Hz Gain 5.0 dB Q 0.700 Filter 3: ON PK Fc 200 Hz Gain 1.0 dB Q 0.500 Filter 4: ON PK Fc 1000 Hz Gain -4.2 dB Q 0.900 Filter 5: ON PK Fc 1750 Hz Gain -4.0 dB Q 1.400 Filter 6: ON PK Fc 2300 Hz Gain -3.2 dB Q 3.000 Filter 7: ON PK Fc 2800 Hz Gain 3.0 dB Q 2.000 Filter 8: ON PK Fc 3100 Hz Gain 1.8 dB Q 0.500 Filter 9: ON PK Fc 3400 Hz Gain 10.0 dB Q 1.500 Filter 10: ON HSC Fc 6000 Hz Gain 8.0 dB Q 0.700 Filter 11: ON PK Fc 8300 Hz Gain 5.0 dB Q 3.000 Filter 12: ON PK Fc 10000 Hz Gain -3.7 dB Q 0.700 Filter 13: OFF HSC Fc 12000 Hz Gain 3.0 dB Q 0.700
AMT EQ 2:
Code:Preamp: -12 dB Filter 1: ON PK Fc 20 Hz Gain 3.0 dB Q 0.700 Filter 2: ON LSC Fc 90 Hz Gain 6.0 dB Q 0.700 Filter 3: ON PK Fc 200 Hz Gain 1.0 dB Q 0.500 Filter 4: ON PK Fc 840 Hz Gain -1.6 dB Q 2.000 Filter 5: ON PK Fc 1110 Hz Gain -2.0 dB Q 0.800 Filter 6: ON PK Fc 2300 Hz Gain -2.2 dB Q 2.000 Filter 7: ON PK Fc 3000 Hz Gain 8.0 dB Q 2.000 Filter 8: ON PK Fc 3800 Hz Gain 2.0 dB Q 2.000 Filter 9: ON PK Fc 4000 Hz Gain 5.1 dB Q 0.500 Filter 10: ON PK Fc 6200 Hz Gain -2.9 dB Q 2.000 Filter 11: ON PK Fc 8300 Hz Gain 8.0 dB Q 4.000 Filter 12: ON PK Fc 9000 Hz Gain -5.0 dB Q 1.000 Filter 13: ON HSC Fc 12000 Hz Gain 5.0 dB Q 0.700
