I don't have that problem with this DAC/amp, and it is always on and frequently not playing sound since it is connected to my Mac at home which never sleeps, and previously I used it at work on a Dell PC running Windows 10 and never encountered that.
However, I *have* had that experience with one other DAC/amps on the work PC, a Yulong U100, and turning it on and off did fix it every time, so I think I know what you're describing.
Do you have another computer to test the Monoprice?
Quick question for all those who owns this amp/dac, I have a weird issue with the dac portion of this unit. If i step away for a few hours with the amp/dac and my pc on with no sound playing, the unit needs to be turned off and turned back on before I can listen to anything otherwise it would sound muddy and static-y. Anyone else have this issue?
Just an FYI, I have the unit going to a DTA-120 through Line-Out. I removed it to see if it was causing the issue but I get the same results with just using the dac/amp with headphones.
