I've now had the M1070C for about 3 months and after some (extensive) modding they've taken over the spot as my #1 headphones from the (extensively) modded M1060C.
These are quite hard to drive with 60 ohms impedance and 90db sensitivity, roughly the same as Abyss AB1266 but less so than HE6(se) or LCD4. So these will benefit from a more powerful amplifier. Conversely, with the higher impedance (than M1060C) these can have better impedance matching with tube amps if they're powerful enough current-wise.
EDIT: It seems that the manufacturer's specs have changed and are now 60 ohms and 97db. However, those are the same as for the M1570C and ASR measured M1570C at 64 ohms.
I'm happy to report that the same kinds of mods that work with the M1060C work well with these too. However, the M1070C's overall structure is clearly less modding-friendly and the mods can be more diffcult and risky to implement than with the M1060C.
Here are some measurements from my MiniDSP EARS:
(The 4,5kHz spikes may not be real as the EARS sees nearly all of my headphones as having one)
M1070C stock vs HE6se
M1070C stock vs M1070C modded
HE6se vs M1070c modded.
As you can see from the last graph, the difference between the modded M1070C and HE6se is close to how you would EQ HE6se to make them Harman correct.
Compared to the stock M1070C the mods gave more bass, more treble, more warmth and more accurate mids. What the graphs don't show is that soundstage was vastly improved and any harshness/roughness removed. I suppose there are still some things that could be done to further fine tune them but at the moment I'm too happy with them to be bothered.
The mods I did included the following:
-Remove front fazors and their plate
-Remove rear fazors and install some of my own design ( for this the stock fazors needed to be bent and broke off their plate, as the plate itself is needed there for many reasons)
-Remove all of the thick stock damping material and replace it with better material in better shapes
-Use
these pads in 110mm size
So in the end with the mods the HP's are fairly harman correct, have good soundstage and detail and the kind of bass that comes with the Audeze-style wide and flat magnet structure. They do need a powerful amplifier though as was stated a few posts back.
