You got me thinking about this, so I decided to listen to these headphones w/o EQ, and I removed my tube preamp out of the chain, and started playing with the Impulse Filters. (SMSL M300 MKII with a AK4497 DAC into an Asgard 3) Straight up, the default Fast Sharp impulse (FL1) sounded best, tho the M1570 still sounds dark, and I would still EQ it. Then I reconnected the tube preamp, which uses Sylvania JAN-CHS 6AK5 tubes. And w/o EQ, FL1 sounded pretty good, but a touch leaner. FL5 (Super Slow) gives me more bass slam, and SMSL describes this impulse as the "Natural Sounding" choice.
Now I have to redo everything to see if I can get it perfect w/o EQ. Aarrgghh.
EDIT: I wound up back where I started. The Super Slow (FL5) and using the default Sound Color 1 (What do these do anyway?) gives the vocals more dimension, and sound most natural to my ears. I can easily visualize the artist performing, as it sounds the most like an actual person before me instead of a recording. The other impulses have the tendency of rounding off the vocals, and they come across as more compressed dynamically, and a bit more forward.
@abccpu I wouldn't classify the SU-9 (ESS DAC) + Monoprice 887 as "warm and relaxed"
On another note, this is a testimony to the quality of the M1570, that changing the Imput Filters of the DAC are very apparent. Most people find that they can't tell the differences. I can, and it's easy to do.
EDIT2: After testing the cans on other sources, I came to realize that something was wonky with the SMSL setup. I wound up changing the USB cable and moved it to a new port, letting it reinstall, and now it sounds more normal, and my EQ is VERY BRIGHT. Going to restore the EQ to Oratory1990 defaults and tweak from scratch. The sad part is I don't know what caused it. It could have been EQ APO's driver hook, or some other component, or that iffy contact on the gain switch of the Asgard 3 when on High Gain.
