Originally Posted by krmathis /img/forum/go_quote.gif
Stax 4070.
Afaik they were originally designed by Stax for a major Japanese TV broadcasting channel, for exactly this task - monitoring. The text on the cups should give a hint as well.
You had to bring these up.. I'd love a pair. Look so beautiful.. To the op, the 4070 is the most expensive, & arguably, the best studio grade reference monitoring headphones in production today. The DT48 is the most expensive dynamic studio reference grade monitoring headphone on the market in production.. Both have great build quality.. The 4070 looks more luxurious & high end, (
& coming from a DT48 fan, even more resolving & detailed) while the DT48 has a more vintage/industrial look to them.. The DT48 is also endorsed by NAGRA, which has very high standards..Used for field work & recordings, etc.. Very mid centric.. I would describe them as polite, but really depends on what you feed them.. They are non bright, full sounding, stellar imaging for closed headphones, without a hint of smearing.. They been in production for 73 yrs so they must be doing something right..
But if you want the best reference monitors, I'd get the 4070. If you want the best on a budget I'd get the DT48, which can be had used for under 150.00. Then of course you have the tried & true 240DF/Pioneer10, which are no slouch either, & the, every studio has one, entry level Sony model that was brought up earlier.
Can't leave out the HD600, even though they are open.
