aceedburn
They’re all made in Malaysia, my country!
No, just stay in the J region that you used The Tool tricks
The software regions is accordingly to the sticker on the side of the player
I always wonder why J model has Korean engraving / label but not JapaneseWhats funny is I was in e, aus , je region according to my sticker and now I am U hehe )
are this the same that we have? if not it will be awesome to know!Two new firmware mods from deck24.
Direct link: https://pan.baidu.com/s/10gZngVrhv9xXsQF6a7e4VA
Pass: rown
not new...but with my wm1a (J region) DMP-Z1 1.01, WM2Z, DMP portable Musical ( whitigir) are all on warmer side with good bass...Is there any new firmware which brings a bit more warmth & bass to the 1A? if yes which one? I'm already with a J firmware I guess
Thank you
Yes. But portable fun is the warmest of them all. The bass doesn’t get better than this.not new...but with my wm1a (J region) DMP-Z1 1.01, WM2Z, DMP portable Musical ( whitigir) are all on warmer side with good bass...
regards,
Simon
It really has awesome BASSYes. But portable fun is the warmest of them all. The bass doesn’t get better than this.
if you guys could lower gain a little bit if posible... I think guys with crappy gear like me could take more advantage of the difrences... between each FW release, just a little advise please let me know if they are diferent so I begin tetsing asssap!Disclosure: Since the discovery of firmware tuning, I have been working withLast year some Chinese enthusiastic worked out a way to modify firmwares and change their sound. ATM I won't dive into disclosing the technical specifics since it may be illegal and ultra troublesome to write, but the results are something profound. I will first elaborate on some basic principles.
Firmwares do affect sound(nonsense... we all know that). The firmwares of 1A/1Z provided to download all over the world are universal and totally identical (identical MD5 value). But there are TWO SETS of tuning codes to tune 1A/1Z separately, stored WITHIN THE SAME FIRMWARE. The firmware file simply identifies whether your device is 1A or 1Z then it applies the proprietary tunings accordingly. It reads the identification codes stored within the firmware and your devices as references to preceed the installation.
Secondly, firmware file contains two parts: the first part with the basic system functionalities, for example, the random / repeat buttons shown in now playing, introduced in 2.0; the usb dac / bt receiver modes introduced in 3.0, etc; The second part is the tuning codes, which are scattered in various sections of the firmware. We don't know how exactly the codes work, as they remain an encrypted black box. But we can switch the "box" between 1A and 1Z to alter each other sound. Thirdly and most importantly, the firmware of DMP-Z1 & ZX300 are of similar structure with slight differences of the functionality part, for example, DMP doesn't even has a skip button in the UI while 1Z does of course. HOWEVER, the tuning codes of DMP can be applied to 1A / 1Z perfectly fine.
Incorporating DMP's tuning, both 1A / 1Z enjoy a much expanded sound with better extension on both ends. With the new assets at hand, theoretically speaking, tuning codes can be switched and combined to approximate the desired sound profiles of many other DAPs. Yet the process was HIDEOUS, since it's a shot in the dark for modders to blindly test the wild combinations with our own ears. Thx to our Chinese pioneer, Deck24, who relentlessly keep experimenting the tunings with months of trials and errors, finally there are some results to be shared to the public."the Step-Father of Walkman"@Whitigir to create and share a series of modded firmwares "in conspiracy". Theoretically speaking, each of these firmwares is a clear upgrade to your Walkman, but remember that your hardware limitations will play the bigger roles that scales up with the firmware performances.
The following firmware mods will bring about the sound signatures of DMP Z1 fine tuned for the Walkman. There will be differences as DMP Z1 and Walkman are too different in hardware engineering, sizes and implementations. If you are not happy with what you hear, please use the stock firmware, as there has been no known risk of damaging or bricking the player.
Both 1A and 1Z are tuned exactly and the same. Four sound profiles were composed, tastefully and painstakingly. They are Mercury, Jupiter, Mars and Venus for you to choose from:
Among all these 4 profiles, we also divided each of them into 3 different Tiers for various levels of setups. You can choose freely for your own preference. So there are a whole combinations of 4x3=12 versions to choose from.
To put in a nutshell, these firmwares are all about SYNERGY with your hardware. The higher the Tier ranks, the better hardware will scale, and the higher output power (illusionary). T3 or Mercury may not fit the majority out there, although they are the most technically capable.
For better performances, please also change regional code into Japan.
Another Chinese fella accidentally found out that Japanese model of 1Z (not sure about 1A, but should also apply) sounds smoother than the Chinese model (region CN). With some research, he found that the Japanese model and other regions' model are applicable to different tuning codes, thus resulting in the difference of sound. Generally speaking, JP tuning has smoother timbre, better bass texture and a tad deeper/larger soundstage.
To obtain the Japanese tuning, simply run the Rockbox tool to change your region code to J. You can also find the Rockbox tool in the Win-exe sharing folder.
How to change region code to "J" using Rockbox tool
P.S. You DON'T need to factory reset to activate J tuning! Don't reset or you will lose your clocking hours. Just restarting will suffice.
After changing to J, please run ANY firmwares again for your device to apply to the J FW. Restarting your device, u will find a new certificate item showing up at the bottom of setting's page, proving your FW is now the Japanese version. At the same time, u lose the ability to change language to others, but keeping your current language (such as English). Because Japanese FW initially doesn't support multi-language selection.
Upgrade methods: first make sure your device is on official 3.02. The mods are all based on the official 3.02, keeping all its vested functionalities. If u upgrade from any other official versions the installation will fail, though no harm will incur at all. The upgrading speed is much faster than official upgrade since only the tuning parts are being written in. The process is perfectly safe for your device, and you can always run the other mod to substitute, or revert back to the official FWs anytime by running their exe.
Choose the correct version for your device model to install. All devices except JP model and EU model should choose Universal. Unfortunately I cannot compile and maintain Mac versions.
Please allow @Morbideath and @Whitigir some time to relax. They have been busting ass for a while and still have work to doSo are this new frmwares diferent from what we have? if you guys could loweer the gain a little bit if posible... I think guys with crappy gear like me could take more advantage of the difrences... between each FW release just a little advise please let me know if they are diferent so i begin tetsing asssap!
