hamhamhamsta
Stop poisoning the guy,Have you tried 1z yet?
There is 3 top daps
1z
N8
Lpgt
Sp2000 cc
Maybe new dx220 max
There is 3 top daps
1z
N8
Lpgt
Sp2000 cc
Maybe new dx220 max
Did you mention DAP as in Digital Audio Player ?Have you tried 1z yet?
There is 3 top daps
1z
N8
Lpgt
Sp2000 cc
Maybe new dx220 max
Add DMP Z1 as well
Well, you didn’t explicitly exclude or include the price range, only mentioned the best DAPThere is only 1 way to know right?
Buy them all at same time and test it !
Make sure you got enough buffer on your credit card haha
I didnt add it there as its a very tough financially to achieve digital player hehe
You can Use most all Dynamics, but I don't think most planars would work well, unless they are the smaller portables.Anyone know what the power output of a K-Mod or Romi mod is? Will it be powerful to run some cans in 4.4 balanced? Thanks!
The caps are back in stock!
@Nayparm how is your KaeSei player doing? Any details on sound breakdown please?
Also have you had a chance to listen to Blackgate Capacitors? I would appreciate any comparisons between the Romi Mods if possible
Hope you get your player back up and running soon, and yes capacitors are back in stock at a few places nowI had to pinch the 100uf kaisei caps from mine for someone elses so mines been out of action. I haven't used blackgates for a long time due to price, availablity, dubious spec tolerance and life expectancy of something ancient before you start.
Get them while you can
