Rick : we're mixing way too many different things here. |
I am in the middle of something "off site" so will have to get back to you with the documentation for what I was trying to explain.All there and very clearly layed out in plain english.a zoebal is seriously overkill when a simple resistor will cure the possible ill.Kinda like fishing with TNT.you will catch fish but likely mangle them in the process
You have no idea how much satisfaction a peon like me gets by tripping up one of the grizzled vets here |
luckily I can take it as well as dish it
then again "no where to hide" means just that
Seriously though, the Millet is probably the only totally feedbackless amp circuit floating around here. It is easy to forget. It should have a logo with circle and bar or something like that. |
You are right about that.I have been SE/Open loop for a while but my amps are hardly DIY project material.The Millett is most likely the absolute biggest bang for the buck amp done as a straight build with no fancy parts yet having enough wiggle room to make it "Mongo Amp' to suit any taste.Pretty cool really.
I run mine with the discrete bufers and I was pondering taking them out, just for some entertainment value and a change in pace. I agree though, that with an average of 0.25% to 0.50% THD and IMD, it kind of takes the edge off many of the tweaks. It's like the good old days when men were men and amps put out a little distortion and that's just the way it was! |
it has been proven beyond any shadow of doubt that an amp speccing in at 0.001 %THD (TL072 opamp for one) can sound way worse than one having even 1% distortion and the human ear has a way of liking things test equipment does not and dispising things loved by the bench technician who is all about numbers and comparing specs but never actually listens.
always wondered why some feel they should be ashamed somehow for liking the "sound" of something because it does not rip to shreds other amps that sound worse in specs.I am pretty sure my main power amp rolls off around 30hz and highly doubt it is dead flat at the top yet is
sounds better than any other amp I have ever owned bar none so I have no desire to replace it until I can find a way to get the
SAME sound in a higher power amp (mine is only 8 watts
The better-sounding bias point often has more distortion in it, but it falls in a different harmonic than that of the lower distortion point of operation. |
The old "lean and mean" or "ballsy" from the guitar amp biasing sector.Same amp,same parts,nothing but a bias change,two entirely different creatures.Works for guitar amps because a musician is all about expressing what THEY want you to hear,a home amp you try for the romantic side of nutral because you are not trying to change as much as enjoy what is already recorded.
to make matters even worse there is no "one size fits all" since we all have varying grades of hearing loss,different taste,different headphone/amp balance requirements.all about locking in the sound so it sounds "pretty good" with everything thrown at it instead of it being a "rock" or "classical" or "jazz" centric amp which usually is a prime identifier of extreme coloring and so not close to natural.find the happy medium then close that sucker up tight !
