rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
Originally Posted by NeilR If I were going to mod that board, I would make C2 the same size as the other caps. I think that was a strategical error. I agree with you- they are just as important [just as much in the signal path] as the output couplers. |
I hate to ruin the aesthetics with some big caps air wired onto the board, but I guess it ought to be done. I've been thinking about that for the "educational builds". All I used for C7 was a Cerafine. I'm haven't gotten into boutique caps [yet]. |
Originally Posted by rickcr42 Check the rest of the Keystone catalog.There are so many pcb mount options from available them that if not there it likely is not availabvle anywhere ! (have you considerd a simple hard metal "hook" type post ?) Good company with great service,unique parts and great prices.One of the true DIY Supply good guys |
Originally Posted by n_maher I'm not sure I agree with this statement, but I won't fight it. When I look at the schematic I don't see how C2 is in the signal path. So wire the caps under the board Nate |
Do you buy direct from Keystone? |
Originally Posted by NeilR Here is some homework... Note his reference to ck as an ac bypass and the discussion of shelving frequency if the value is too small. If that cap will shelve the signal, it is in the path. Or maybe it is just one more example of internet misinformation |
Originally Posted by NeilR Nate - don't feel bad about the "mistake" with C2. Pete Millet got it "wrong" too, if the current line of thinking is correct. |
This is the achilles heal of this topolgy and the reason why the ultrapath is so clever, and why it performs so well. |
