psy472
Based on his chain, only mid fi headphone would sound good. I didn’t buy into his reviews because my DAC/amp is too different from his.I hoped after his first failed review he would apologize and make and objective review. But I was wrong.
1. In his first review he stated that Arya was technically better headphone which was absolutely not true
2. Now in this second review he stated that hybrid pads were congested, bloomy and bloated - and that's not true neither
3. He stated that some adapters would fix that. Yes, they can do some improvements, but no adapters can fix a bad headphone as he was saying
I can't trust WaveTheory anymore.
The problem with Tungsten is that its driver space is a bit too compacted from between the driver and your ears so there is no room for the air to resonate and give that bass slam. Some of the washer mods shows that if you just added 1-2mm of depth the bass slam would be harder and the sound clearer. The adapter is meant to give the space, but what I see that adapter in the vid added a solid metal filter between the ears and driver which may reduce the treble a bit.
