MMCX cables for cable down iems?
Mar 10, 2024 at 4:33 AM Post #2 of 5
You can find them on AliExpress--KBEAR makes at least one, for example. Try searching for Shure mmcx cable.
Mar 12, 2024 at 9:49 AM Post #4 of 5
I'd say depending on your budget and type of cable you want/need, you can also probably just ask the cable maker to make yours without ear hook.
Mar 12, 2024 at 10:05 AM Post #5 of 5
I need a new cable for my Sony Xba-N3 that use mmcx and hang down so I’ll have a look at the links above and keep an eye on this thread for any updates, I’d prefer a supple thin cable with a small 3.5mm Jack.
:thumbsup:
