I`m testing it with two CD players via optics and coax in same time - booth works but I`m put them on pause to make AMP louder to check for noise (at my usual listening volume). I`m measured TDA`s voltage - all have 7.58V with 9v wall wart and some time later I heard loud click and then Left`s channel crackling noise is gone. It was completely sounds as it`s should. I turn DAC off to cool down to checked again later - left channel crackling noise was there but after one minute warm up - after a click sound noise is gone again.You did not say you got sound or music. Did you? Did you get music in both channels? What were the voltage in and out of the new LM317? Is the voltage out around 7.5 volts with the 9 volt wall wart? Do you get a similar voltage on pin five of all four TDA1543 chips? Or just one channel? I don't know what is causing noise in one channel. The digital noise MAY be coming from one bad TDA1543 chip. But check the manufacturer's solder first. I'm just guessing here. Does toslink and coax both work?
LM317 voltage is wierd - only 1.7V and 1.2V - if I`m measuring it right (touching ground with one probe and pins with another (without any resistors)). Sorry - I`m not electrician and English is not my native language.
