ByrnesK
Cool, thats the silver and copper hybrid cable right? I'm feeling the looks of the full copper hahaÉros S (8 wires) seems to be great.
Yes it's the hybrid silver and copper cable. Pure copper wires and pure silver wires.Cool, thats the silver and copper hybrid cable right? I'm feeling the looks of the full copper haha
Ill check this one out, Have you heard of the EA Ares S? I have heard its a decent match up with Hybrid IEMs
Hi, Just picked up my End game IEM's UM MEST MK2, Stupidly bought it with the 3.5mm cable and now looking to pickup a 4.4mm cable moving forward. Any suggestions on Quality cables (Very controversial but I lean more towards the look/feel/quality/flexibility side of upgrade cables), Love the look of copper cables, Open to cables that have swappable connectors, What cables do you guys suggest? Thanks
Copper cables have its uses, I use pure copper cables on earphones with a bit too much treble emphasis or are analytical in tunings. Helps bring body to the sounds without highlighting the treble aspects of the tunings. SPC cables are actually more versatile as it usually adds on top of pure copper properties that added treble emphasis that pure copper can be missing at times. It is the SPC type cable that give the best balanced type emphasis vs a pure copper or pure silver type cables. This is the reason why you see more SPC type cables in the market than just about any other type. It really depends on what part of the sound profile you're trying to enhance or not pay attention to.Hi,
I went through the 74 pages to get you recommendations on cables. I have IMR IEMs that have a full bodied sound and are not analytical a lot. Based on what I have read in this thread, I shortlisted 2 cables: Penon Mix, Cema 175 and Penon OS849 (although I was told that pure copper has better performance than SPC). Penon Leo Plus is unfortunately out of my budget. Between Mix, 175 and OS849 cables, which one would you recommend?
I have already ordered Cema PS Series that has a mix of paladium, copper and silver. I will share my feedback once I receive it
Thank you for your reply. If I had to buy a second cable, which one would you recommend?Copper cables have its uses, I use pure copper cables on earphones with a bit too much treble emphasis or are analytical in tunings. Helps bring body to the sounds without highlighting the treble aspects of the tunings. SPC cables are actually more versatile as it usually adds on top of pure copper properties that added treble emphasis that pure copper can be missing at times. It is the SPC type cable that give the best balanced type emphasis vs a pure copper or pure silver type cables. This is the reason why you see more SPC type cables in the market than just about any other type. It really depends on what part of the sound profile you're trying to enhance or not pay attention to.
I would try that Cema cable you ordered that seems to be a good mix of properties and should be versatile to use on your IMR IEMS.
Check out XINHS on AliX makes tons of cables for many companies but sells directlyThank you for your reply. If I had to buy a second cable, which one would you recommend?
Actually I was interested in the mix cable (pure silver and OCC) from XINHS, but i have been told that build quality is excellent but they do not sound amazing like CEMA cables. In addition this cable in particular is too good at this price to be true (40$). I doubt it has pure silver in it, otherwise Penon would not have sold a similar cable at 149$Check out XINHS on AliX makes tons of cables for many companies but sells directly
You could consider the ISN G4. It is an all rounder cable, which gives body and weight to the low frequencies, and accentuates the details. I have two, one on mmcx and the other on two pin. I also have the penon MIX, and although it is a great cable, in all the iems in my collection, doing A-B tests, I have always preferred the G4. Once you are convinced that there are differences, and you feel them... It is difficult to go back. There are times that you will be wrong, and others in which you will discover wonderful synergies. The easiest thing is to listen with the stock cable, and ask yourself what you would like to improve on that IEM. Luck!Thank you for your reply. If I had to buy a second cable, which one would you recommend?
What do you want to know mate? i didn't understandIs someone here knows the iem cables "Artic Cables" offer ?
Same question with "Satin Audio, monsters serie, Kraken III and Medusa III" .
Thanks
Got it, well I've read only good things about these companies. I don't have an Arctic but a month ago I ordered a satin, theia ii, so the basic line, but I'm still waiting for it, so no direct feedback to give you.Is someone here has used these cables yet ?
Are they good in other terms ?
