What part of the Blessing 2 dusk would you like to enhance. Its detail aspect? Mids bass with less treble or the opposite more treble and detail with less bass emphasis?
I personally love the Penon GS849 on my Blessing 2. Fixes the lack of fullness and dynamics for the standard blessing 2. I have not tried it on the Dusk so I have no idea how well it synergizes with it. This cable will bring some significant changes for the better but it costs $150. You can get the
You can get the ISN GS4 which is the 4 cored version of the GS849 for less than $100
https://penonaudio.com/isn-audio-gs4.html
The difference in 4 cored and a much more thicker 8 cored version is the difference in material thickness which influences the IEM sound more so than the 4 cored. Both do the same thing as far as sound shaping goes but the 8 cored version usually gives a thicker note weight and a slight expansion of stage over the 4 cored variant.
If you want something that will be a clear upgrade from the included cable with a smoother treble response the ISN G4 is what I would recommend.
https://penonaudio.com/isn-audio-g4.html
