DTgill
Here's what Jiun wrote back to me in regards to using 6SN7 tubes in my Istanbul "yes, will not hurt to dac. many users did it already."Is it safe to use 6SN7 in MHDT? It draws 0.6 Ampere instead of 0.35
You should send an email to mhdtgang@yahoo.com and ask they can give you the information you need.What about 6CG7/6FQ7 tubes?
They have a noval, 9-pin miniature base and some people use them in lieu of 6SN7.
I am not planning to further my quest in finding new tubes for my Canary dac. I just wondered if anyone has tried those cheaper alternatives for 6SN7.You should send an email to mhdtgang@yahoo.com and ask they can give you the information you need.
Jiun was quick to respond to all my questions.
If it is General Electric, then it should be 5670, am I right? It can replace a WE 396a tube. Could you check and specify which tube it is, please?I just received a GE 396A put it in my Istanbul turned it on, turned on my Lyr 3 and put on my Anandas', audio heaven, oh yeah! I'm in the middle of the concert, Jason Upton, Bob Dylan, I'm there! This tube has added a dimension I can't explain, other than it's like a cool drink on a hot day, very refreshing.
I went back and relooked at it and it's a Western Electric my bad, you are right.If it is General Electric, then it should be 5670, am I right? It can replace a WE 396a tube. Could you check and specify which tube it is, please?
You should contact Juin@MHDT Labs.I've got a feeling I already know the answers to what I'm about to ask but here's hoping against hope...
I bought an Orchid on US Audio Mart and received it earlier this month. It came with both the stock and WE396a tube upgrade. It worked great and I fell in love with its sound rather quickly--even with a balanced Pagoda in the mix as well. Today, after a few days of not using the Orchid, I fired up my system and sat down to listen to some TDA1541A goodness only to be greeted with silence. I checked all connections, unplugged and re-plugged everything and got the same result.
For note, in the main system, I use RCA coaxial via a Pi2AES for the Orchid's input.
I power cycled the rest of the system and still got silence.
I powered down, removed the WE396a and replaced it with the stock Westinghouse tube. Same result: silence.
At this point, I was getting nervous something happened to the preamp (Apex Hifi Pinnacle 2 Ultra), so I turned on the Pagoda as well and since that's using AES, I could have it playing on input 1 with the Orchid on 2. The Pagoda assured me the issue is localized to the Orchid.
To be extra sure it wasn't just the coaxial input, I took the Orchid to my headphone rig (Bifrost 2 + EAR HP-4) and hooked it up using USB at first. Silence. In a moment of desperation, I cranked the volume up to 100% and was suddenly able to hear output at the faintest levels from the Orchid. It sounded extremely distorted. I tried swapping tubes again but same result: no audio until the volume is cranked all the way up.
Finally, I hooked up my X-SPDIF 2 and used the coaxial out on that with a different cable to just to make 100% sure there wasn't some weird issue with the coaxial cable in the primary system and it was the same as USB: silence until 100% volume and then barely-audible garbage.
Has anyone run into this and found a weird solution? This reminds me of the Sonnet Morpheus and how it behaves when not in DAC-only mode with the digital preamp down to -40dB except there's no preamp in the Orchid...
I contacted LTA about getting non-warranty repairs but am not expecting to hear anything for a few days if at all. Sigh, this really sucks.
Welcome to the club.Hi everybody, an Orchid owner for 4 months now and really happy. I am debating whether I should upgrade it or stick with it and I have several questions.
1. Upgrade option - where do I have to go to a really better result? I have an Audio Note 300b amp and Audio Note speakers so you probably get a gist of my sound taste. There's one thing that got me thinking this way and that is the amount of DSDs I have in my library. I always wonder if I am not losing anything when Roon needs to output PCM to my Orchid.
2. And if I keep it (which currently is my feeling) : I got a very nice Philips miniwatt 7308 NOS which I wanted to tube roll to my DAC. I ordered a Garage1217 adapter but due to customs issues (long story) it was sent back to the US by the Belgian Post. So I ordered an adapter from Aliexpress but when I inserted everything in I really didn't like the result. Maybe the adapter is of low quality?
