bpiotrow13
It is labelled as E188cc / cv4108 acually.The Mullard E188CC is a very good valve! Very likely the same as the CV2493 which I love,
What would you say is the highest value of going to E188CC versus the original family? I’ve got the Orchid for a while and tried quite a few highly rated tubes with great results. Wondering what the E188CC family (or specifically the Mullard E188CC) brings to the table that top tubes in the original family don’t have? Many thanks.The Mullard E188CC is a very good valve! Very likely the same as the CV2493 which I love, or very close indeed to it. I've seen some Mullards labelled with the two marks, E188CC and CV2493.
I think you have the best sounding on the planet of the 6922 family - and it's great to know you like the sound.
I'm sure the Tungsram mentioned here are also very good. I've had two variants of Tungsram and one was excellent, superb sound, very close indeed to the CVV2493. It seems that 'warp' probably has this or similar.
I'm glad the change to high quality 6922 has worked out well for you both - now relax and enjoy the music!
With the stock tube the Orchid sounded nice but if you roll tubes you can improve it’s sound quite a bit, specially in the bass and details, refinement. Tubes for it are not very expensive and it’s a lot of fun to modify the sound. I still own the Paradisea, one of the first NOS DAC produced by MHDT, the Orchid is quite an improvement but the Paradisea is so nice I kept it for a secondary system.How good is the Sound from the Orchid in Original Version?
Thank you for the feedback.With the stock tube the Orchid sounded nice but if you roll tubes you can improve it’s sound quite a bit, specially in the bass and details, refinement. Tubes for it are not very expensive and it’s a lot of fun to modify the sound. I still own the Paradisea, one of the first NOS DAC produced by MHDT, the Orchid is quite an improvement but the Paradisea is so nice I kept it for a secondary system.
You might also consider the Istanbul in your quest for an MHDT DAC.Thank you for the feedback.
I saw the Paradisea on Ebay for €500, so I'm still thinking about it.
I think it's a bit outdated compared to the others.
The Orchid would be more of a close choice next to an Audio Note 2.1.
The Paradisea would probably not be bad for a start.
I have an Orchid. Love it. I sprinkled a little touch of extra warmth on via tube upgrade. Also, agree with @DTgillThank you for the feedback.
The couple of times I've had a question, they responded in a timely manner.Hello,
I have contacted Mhdt Labs and the support there seems to be currently not staffed to answer questions.
Is this normal or is there a reason?
I saw the Orchid on Ebay.com for a short time and it was quickly removed from the auction.
Everything seems to be a bit strange.
I'm still looking for a store if possible Europe and not the Danish that there is, because it is quite expensive.
The one in Canada does not have the Orchid and the one in the Usa I have not yet inquired.
Would be a shame if there was a lack of support.
Hello,
If you find the Danish shop expensive (yes, their is a significant price difference - but don't forget the price includes shipping, customs clearance and VAT), you can also buy your Orchid directly from MHDT LAB. You find all the necessary information on their website. I did that when I bought my Canary.Hello,
Could you post a link?MHDT Labs Orchid 69SE with TDA1541 double crown chip and 6922 tube
Just noticed MHDT offered one of these on ebay. Significantly more expensive than the standard Orchid. Very different appearance. It's got me really curious. Anybody here had a chance to listen to one of these or know anything about it? Looks like MHDT obtained a small quantity of the double-crown chips and decided to modify the circuit to allow use of 6DJ8/6922 family of tubes.
