Arcayne
For me, and many others, the stock cable is a major pain. It's too long, and because it's a flat cable it's not very pliable either. So I pretty much immediately ordered an upgrade cable (Meze's silver-plated upgrade cable terminated to 4pin XLR) and an XLR to 6.3mm TRS pigtail adapter from Forza Audioworks. So it might be good to keep in mind that you may find yourself wanting to purchase an aftermarket cable as well. Just try to avoid very cheap cables and adapters. I've tried a cheap cable and a few adapters from AliExpress, and they all degraded the sound noticeably compared to the stock cable.Got word that Empyreans have arrived. Picking them up from the dealer tomorrow. Very excited. Anything I should know or prepare for getting them new?
My current setup is an Asgard 3 and Bifrost 2 stack. I know the Asgard 3 doesn’t really pair well, so I have a Jot 2 on the way (probably be a couple months due to the Schiit shortage). I’ll be running SE until the Jot amp arrives.
I have owned the Asgard 3 before and currently own a Jot 2. I agree that the Asgard 3 isn't a great pairing with the Empyrean, but it's definitely not bad either. The pairing is just a bit too warm and mellow sounding imo. The Jot 2 will provide a nice upgrade in overall technicalities, and it has better synergy with the Empyrean as well. It's my go-to recommendation for an inexpensive amp to pair with Empyreans, so I'd say you certainly made the right call ordering a Jot 2.
Other than that, if you're looking for a headphone stand that matches the Empyrean's headband radius seamlessly to prevent potential deformation over time, and you're not opposed to spend a pretty penny, I recommend a ROOM's Audio Line FS Pro A.
