ken6217
Amended below
i think that all three exude superb build quality and attention to detail regardless of the different materials used in their manufactureAs a previous owner of the Z1R and the Utopia. The Utopia build materials "plastic" doesn't even compare to the Sony. None of them touch the Empyrean.
The Utopia creeks and feels flimsy. There is no way around it. It's the design.i think that all three exude superb build quality and attention to detail regardless of the different materials used in their manufacture
After you burn that cable in some please give me some impressions.Even with specs you may or may not like how it sounds and I may not be a true indicator. On paper some may look perfect but not so musical, just accurate. Or what about tubes? Their specs like crap with the distortion but they sound good.
Of course this is a personal thing, but I too wasn't half as impressed by the Utopias as the Empyreans...and this was via 2 tube amps, an extremely good custom built SS amp and Chord's Dave. Especially considering their cost!! They also - for me and in my system - blow the Clear right out of the water (in any area you care to name)...no contest.
Empyrean blows the Clear away. I used to own the Clear and then I reviewed the Questyle CMA twelve Master using the Clear and it didn't get much better than when I used them with the Chord Mojo. That soundstage is nothing special. Dynamic drivers can only do so much.Are you referring to the Empyrean's blowing the Clear out of the water or the Utopia's?
Unless we're stating facts like raw specs, everything we share here is an opinion!![]()
yes, some owners have reported creaking. the design incorporates the use of carbon fibre to reduce the weight of the headphone. while it may feel flimsy to you, it has a high strength to weight ratio (apparently). if you think that the empyrean is the superior headphone then fine, i'm not here to try and make you change your mind. this is the empyrean thread after all.The Utopia creeks and feels flimsy. There is no way around it. It's the design.
I am well aware of the strength of carbon fiber and how awesome it is. The Empyrean has carbon fiber as well. The Utopia has cheap @ss plastic. And cheap plastic on the cups. For something that costs $4k when it was released is a huge disappointment. There's nothing to defend there.yes, some owners have reported creaking. the design incorporates the use of carbon fiber to reduce the weight of the headphone. while it may feel flimsy to you, it has a high strength to weight ratio (apparently). if you think that the empyrean is the superior headphone then fine, I'm not here to try and make you change your mind. this is the empyrean thread after all.![]()
That cable with the Utopia is one of the best ones available. I'm curious to hear it with the Empyrean.Well after about 14 hours of burning it’s very musical, but bass light. They say about 100 hours for break in, and so hopefully the bass will improve, otherwise back it goes.
We all hear differently and I don't fancy any of the HD800's. Or Sennheiser for that matter. Just isn't my cup-o-tea.In my system, the HD800 is neck to neck with the Meze and someway surpassed it. It has more air and able render space better. The Meze has better punchy bass however.
I think the HD800 is very capable if you have a really good amp to deal with them. My favorite amplifier so far with the HD800 is the ECP Audio L3/Ravenswood and Audio-Trchnica HA5050H.
Where to get that ECP Amp? Hearing lot of good things about itIn my system, the HD800 is neck to neck with the Meze and someway surpassed it. It has more air and able render space better. The Meze has better punchy bass however.
plastics are used in high-end loudspeakers. given that the utopia contains premium leather, beryllium drivers and carbon fibre, why do you think that focal elected to use a "cheap @ss" plastic for the ear cups?I am well aware of the strength of carbon fiber and how awesome it is. The Empyrean has carbon fiber as well. The Utopia has cheap @ss plastic. And cheap plastic on the cups. For something that costs $4k when it was released is a huge disappointment. There's nothing to defend there.
