Anyone running the pavane with active monitor. I was thinking about getting the pavane to output to focal solo 6 be or the solo twin directly.
What setup or additional items recommended apart from the usual interconnecting cable? Do I need a preamp? Would I be able to use spl phonitor 2 for both headphone and active speaker duty?
I am running the Metrum Acoutics Pavane to active monitors both Adam A7X (at home) and Focal Trio6 BE (in studio).
All you will need is two balanced interconnects (XLR). Just make sure the negative return and ground is not connected on the cable for the best performance.
I have seen some cable manufacturers connect the two (not naming names).
To get the highest level of sound quality one must eliminate the use of multiple gain stages (volume adjustments) because it increases the signal path through the creation of joint connections. These extra "interconnects" will negatively influence the sound quality. The idea of being able to control volume through a single knob great, but the same can be had if you control it through your source (laptop, c, player). Now the issue here is that the Focal's do not come with a volume control so you will need a pre-amplifier that has a volume control.
If you are using the SPL Phonitor 2 as an amplifier for your headphones then based on the look of it, it could also be used as a preamplifier. It would probably serve your purpose better as you are able to use it for headphone listening as well as being able to control both the headphone and speaker signal from a single place.
At home my A7X's already has a volume control so a simple XLR cable goes directly from the Pavane to the monitors. If I were to use my headphone amplifier as a pre-amp for my speakers, it would take the projected signal from the DAC and run it through the headphone amplifier's circuitry which in turn adds additional noise into the signal and lengthens the path that it needs to travel. This isn't desirable as it degrades the sound quality. All of this needs to be done just to control volume from one place which is why I personally feel that it is better to do so from the computer source UNLESS as mentioned prior, if only your speaker does not have a control of it's own then a preamplifier is highly recommended. This is why the Metrum Acoustics Adagio is so highly regarded. It works as a DAC as well as a pre-amp. It's pre-amp adjusts the R2R Ladder in a way where it doesn't degrade sound quality so it would be a perfect item for monitors or loudspeakers that do not have volume control.
Either way, the issue here with volume knob based studio monitors or even ones without it is that you will still need to do SPL test to make sure the volume level on each speaker is the same. The same test (or similar) is also needed for equalization to keep the frequencies flat for accurate production.
Hope this answers your question.
