META42 Blue Portable pix
post-195978
Post #16 of 30
KurtW
carlo, I got the idea from Tangent's website about using IC sockets for some of the resistors instead of soldering them in. The resistors that set the gain of the amp are in these sockets, so if you changed headphones or for whatever other reason wanted to change the gain of the amp it could be done easily. The LED resistor uses two single pin sockets. The ICs are also in sockets, so changing ICs is also pretty easy. I bet it's theoretically better if you didn't use any sockets for anything and soldered everything in, but I doubt the difference is very audible. The sockets have gold plated contacts which should help long term.
post-195983
Post #17 of 30
eric343
Member of the Trade: Audiogeek: The "E" in META42
Nice!
So KurtW is our newest (I guess) DIYFSE-er... welcome to the fold
post-195984
Post #18 of 30
eric343
By the way - why's there a TO-220 device in there? Crowbar diode?
And what volume control? Panasonic?
post-196039
Post #19 of 30
neil
Wow, that's almost as good quality as the picture of my META42 Blue.
post-196042
Post #20 of 30
JMT
JMT Audio:PPA/META42 Amp Factory
Moderator
Posted by Neil:
Hmmm, lessee
Neil's pic:
MacDEF's pic:
post-196051
Post #21 of 30
carlo
Founder of 5 in heavy rotation
kurt,
thanks a bunch
post-196065
Post #22 of 30
KurtW
Good eyes Eric...yes that's a high current crowbar diode to protect against a reversed battery. The board had room for it so I put it in. The volume control is the Panasonic one.
post-196095
Post #23 of 30
N@Z
MacDEF:
Cool amp! How's about some pics of the innards.. for us fetishes
Nearly got JMT to build me something similar but with an external battery pack but thought against it & decided to get a maxed out META instead. Can't wait!
post-196695
Post #24 of 30
HappymaN
Originally posted by JMT
Hmmm, lessee
Neil's pic:
MacDEF's pic:
Ooohhh... The claws are out...
All these pictures of META42's are making me want to send JMT a PM and get one myself, but my rather gaunt looking wallet is just saying no...
post-196817
Post #25 of 30
x1lexure
Same here happyman... I wish I had the cash to buy.
Looks are important to me. I'm one of those people that believe looks affect how much you like something. I believe that if it doesn't look good but sounds good you'll never be truly satisfied. Sound is the most important thing of course but looks come in second or possibly third behind useability..
post-197076
Post #26 of 30
MadDog5145
BTW What is the battery life on this amp?
post-197083
Post #27 of 30
KurtW
It draws 12.2mA at idle with a 9v Plainview recharable battery putting out 10.0 volts which is typical. The battery is rated at 170mAH. With music playing on low impedance phones the current goes up to around 13.6mA, giving 12.5 hours battery life. Obviously this will vary with different headphones and how loud you play it, but that should give you some idea.
post-197195
Post #28 of 30
tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
nice travel rig there
Yes, the Headroom Airbag works really well with the Serpac H-65 enclosure. I used a similar system myself for awhile, but then I got a PJB-100 for my portable system. And, yes, I have the Headroom bag for it, too. I highly recommend those bags -- great stuff.
Do they make a smoke color?
Yes. Also green, red and (of course) blue.
there seems to be a following for two 9v batteries.
Depends on the op-amp and headphones you use. If you use an OPA627 and Senn HD-580s, one 9V just in't gonna cut it.
post-202683
Post #29 of 30
purk
McDeff,
Where's the review?? Thanks.
post-202730
Post #30 of 30
Voodoochile
Supafly & The Funky Pimps
Nice looking work there, KurtW!
