erix,
glad you posted that pic man - looks like you've got everything. that huge filter cap off the tranny looks interesting... this thing has so many filter caps (at such high capacitance) that its obvious the guys at melos/mar don't like to skimp in that department
outside of that i wonder what the values of the signal path auricaps are - they're a hell of a lot bigger than mine (i used 1uf, 200 or 250v caps for all my experiments per the parts sheet). looks like the board ps electrolytics and resistors are stock, but can't tell for sure from the pics.
the two top auricaps (by the large black high voltage cap and to the left of the top heatsink) are the blocking caps i omitted - not needed if there's no dc issues at the source and to my ears the amp sounded more open. the huge caps on the bottom are once again the preamp output caps, the tiny board by the front of the face is for remote (for those without schematics).
i'm slightly surprised none of the board's electrolytics have been changed (although those are different bypass caps than i had - from the pic they look like the same caps used for the signal path on my stock board - the ones behind the tubes in the closeups), i found gains by going over to blackgates (especially the nx series). i'm sure mar had their reasons though. thats a pretty amp
aeberbach,
man, totally want to experiment with paper in oil as well but that stuff is $$$... when i get around to the preamp section i may give it a shot. gotten a chance to experiment with them yet?
voodoo,
depends man. both amps pictured in this thread are melos gold reference/maestro boards (not sha-1s) so its a bit more expensive. factor in parts and stuff and obviously it gets pricey... damn audiophelia.
best,
carlo.
EDIT - anyone (markl?) know what signal caps mar uses on the normal upgrade?
