rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
UPDATE AFTER 2 DAYS OF BURN-IN:
Hydra-Z is playing now for two days continuously. It has gained in SQ.
Listening fatigue almost has gone, and, to be honest, there's VERY LITTLE difference between Hydra-Z and my MX-U8.
MX-U8 still has a little more low level detail and more low-end control with a little more pressure in sub-lows.
Only problem I have with Hydra-Z are the drivers, those are very old (2 years) and there's no possibility to set low buffers and low latency.
I can't use my preferred settings within JPlay 6.2 which are: Ultrastream / 700Hz / 0.01s / Hibernate ON I'm now on 40Hz / 2s which sounds less open in my system.
For now it looks like Hydra-Z (with external battery pack) sounds exact like my MX-U8. Never experienced something like this before,
no tonal differences, no difference in soundstage, no difference in silence and black around voices and instruments, no difference in dynamics,
just a little difference in low level detail and tightness/pressure sub-low (=<30Hz)
I also tried different external battery psu's, the 15600mAh pack sounds little bit better than 5400mAh model.
Will wait till Wednesday for final verdict, but I expect I will end up with two devices who do sound exact the same![]()
If one is not used to DIY solderwork, and handcraftmenship in general, AudioByte Hydra-Z is a killer!
Until now I still do prefer my modded MX-U8 because of driver compatibility, and the easy of updating them.
Cheers![]()
Alex
Thanks Alex! Wonder what the difference might be with the ZPM? or even the TeraDac?
You may have just reached the maximum potential for this part of the audio chain. Hopefully a drive update soon from Hydra.
BTW Still way cheaper then the Berkerly
