Hi guys,
The AudioByte Hydra-Z has arrived today
I received it without the ZPM external power supply, but I made a connectioncable and connected it to my 15600 mAh Lion usb powersupply.
It's playing now for a few hours. I had some problems with installing drivers. I couldn't get it working with modified XMOS drivers, system did recognize Hydra-Z
bnut I couldn't play any music at any setting so I had to use the drivers from their website, which are dated back to 2013
I also had to find the best settings within JPlay with KS (Kernel Streaming), there aren't many settings I can use with the standard drivers.
This made comparison a little bit more complicated, I had to set my MX-U8 to the same (lower SQ) settings before comparing.
At first I listened to Hydra-Z without external power supply. It didn't sound bad at all, but low frequencies were VERY lame sounding, not tight at all.
So I decided to solder a cable to connect an external powersupply. This made u huge difference, lows were much tighter and overall SQ was better.
First listening impressions (with my own external, heavy battery supply, NOT with ZPM) after a few hours:
The AudioByte Hydra-Z is a very good usb interface.
Out of the box with almost no burn-in time (which it probably needs less because of the absence of power supply / big electrolytic capacitors),
it sounds quite good. I didn't expect this in comparison with my heavily modded MX-U8.
The first thing I noticed was the exact same tonal balance / timbre of voices etc.
For the moment the MX-U8 is still superior to Hydra-Z, MX-U8 has more rest, black around voices and instruments, low level details, no listening fatigue, bigger and deeper soundstage, much tighter bass.
But, don't forget all the work I had to carry out on my MX-U8 to get it at it's present SQ level. Also don't forget my MX-U8 including modifications exceeds the $500 range,,,,
I expect the Hydra-Z to become VERY close to MX-U8, but, there's still the driver problem. It's too old, and it's not possible to set low latency, thus in combination with JPlay
I wouldn't recommend this device. Hope manufacturer will provide a newer driver soon. Also do not forget the performance it now delivers is WITH EXTERNAL SUPPLY.
Maybe it sounds much better with ZPM (which I give a 5% chance in comparison with my usb lion supply), but in that case it will cost you about $1500
Hydra-Z will playing constantly on my system to burn-in, final verdict will follow next Wednesday
Cheers
Alex
