onedigit
- Jun 21, 2007
Thanks ElDanno koto-in and jcx for your replys. It sounds like I’ll be ok with the Move and my new 701’s. But jcx unfortunately I’m unable to understand a lot of what you are saying. I’m not sure where you come down on the issue. Are you saying the Move is under powered? Could you boil it down a little for me?
ElDanno did you try them with the low-gain, high-current configuration? What do you think? Where does your volume pot end up?
Thanks again…
OD
Originally Posted by ElDanno /img/forum/go_quote.gif It can drive them very loud and sound very good to these ears. They are quite loud at 11 o'clock on the volume pot. Mine is using the default high-gain, high-current config. |
Thanks again…
OD
