Iced
- Dec 31, 2005
By switchable I mean switchable voltage out starting from 3 to 12v.
Originally Posted by jamato8 /img/forum/go_quote.gif I wish someone would come out with one that also had an optical in as it is so easy to implement and works great with portable CD players that have optical. |
Originally Posted by jamato8 /img/forum/go_quote.gif I am sure he knows and to say plenty is odd. I can understand why you would want to know what the power out is and it is not unreasonable to ask. The amp looks very interesting and it is nice to have one with a dac built in. I wish someone would come out with one that also had an optical in as it is so easy to implement and works great with portable CD players that have optical. |
Originally Posted by Iced /img/forum/go_quote.gif I have a switchable adapter hanging around but I don't know if its regulated or not. Are all the adapters with switchable output regulated? The answer may help people who are in search of an adapter for their corda moves. |
Originally Posted by Iced /img/forum/go_quote.gif Thank you for your reply. |
Originally Posted by onedigit /img/forum/go_quote.gif If anyone has listened to the 701’s with the Move I would like t hear your thoughts. |
Originally Posted by ElDanno /img/forum/go_quote.gif It can drive them very loud and sound very good to these ears. They are quite loud at 11 o'clock on the volume pot. Mine is using the default high-gain, high-current config. |
Originally Posted by onedigit /img/forum/go_quote.gif Does anyone know the output power of the Move? |
Originally Posted by jcx /img/forum/go_quote.gif how about anyone else here doing some numbers when this sort of question arises? K701 62 Ohms, 105 dB/V I consider being able to reach 120 dB SPL before clipping the amp to be "adequate" this gives 5.6 Vrms, 90 mArms which needs another factor of 1.414 for peak values 128 mApk is a lot of current for a headphone, +/- 8Vpk isn't coming from a single 9V powered "CMOY" SS - only recent surface mount op amp will do this alone, look for AD8397 or TPA6120 buffered op amp types with BFU634 or the HA series monolithics and most discrete buffer or all discrete ss amps should be able to do this with enough supply V (some single ended Class A discrete ss designs may not be biased heavily enough though ) Tubes are rather more hard pressed, transformers could do this if sized appropriatly but decent transformers add ~ $100 to the parts cost so you won't be seeing them in sub $500 amps OTL tube amps would need to be biased at > 250mA and most would require parallel output tubes to reach this current level (there are a very few "monster" tubes like 6S33S which could do the job in singles) you could get by with an amp not able to cleanly drive the K701 to to 120 dB if your musical taste runs to todays low dynamic range over-compressed crap |
Originally Posted by jcx /img/forum/go_quote.gif actually I'm not using dangerous listening levels - really carefully read the Headwize "Preventing Hearing Damage When Listening With Headphones" article http://headwize.com/articles/hearing_art.htm the average level I was using as an example was ~ 90 dB - perhaps I should have said "more than comfortably loud" - but way less than live club levels and quite safe at the hour or so I might devote to a critical listening session - not as background music the +100 dB peaks were <10% of the set’s running time as the brass punched out the theme, the percussion must have been pushing the instantaneous peaks ( for only milliseconds ) 10dB higher the OSHA exposure limits allow 90 dB for 8 hr/day, 2 hr for 100 dB Osha isn't the final word on hearing safety but I'm staying at least 4x below their daily exposure time limit for any level - and not freeing up the time for a critical listening session every day... ..."The numbers" can't tell you what will sound good but the very basics of how loud can this amplifier get with this headphone without clipping (and how loud it needs to get to reproduce music) shouldn't be dismissed/ignored if you really want to get serious about the more subtle issues everyone here seems to feel so important |
Originally Posted by Honus /img/forum/go_quote.gif Does anyone know when Jan will be offering the "Move" without DAC - Hopefully at a lower price point? |
