Always between 12.00-1.00 it's depend on what HP I use.What do you have the MHA200 volume dial set to? Is it noon or a bit higher?
I tried using my Mjolnir2 last night as a preamp (forgot it had that feature) with the MHA200 dial at noon. Not good. Even with the Mjolnir2 gain on high, the volume dial on the Mjolnir was at 3-4 and it sounded terrible.
McIntosh MHA200 Impressions
- Thread starter warrenpchi
scfsanfran
Its alive! But first, dinner (actually lunch for me).
scfsanfran
Can you please tell me where you got your small glass audio component organizer in the pic above with your MHA200? I just ordered the MHA200 and I have a RME ADI Pro SE dac that looks like it would fit well, similar to your set up. Thanks!
Amazon, lol.
https://www.amazon.com/gp/product/B07JPX1M9G/
Proper preamp? Yes, and run the MHA200 at 12 as designed.At the office... Mind wandering... Just realized a few minutes ago there's a 3-day weekend coming up. Then all of a sudden that stupid gain / volume control choice that McIntosh made popped into my head. And then it went back to something else.
Out of curiosity, does anyone have a proper preamp and an MHA200? Like one of the Schiit Freyas or something higher up the food chain? Like a C49 laying around? Just wondering what it would sound like with the knob at 12 and a preamp controlling the volume. I have an old Asgard 2 sitting in storage I was using as a preamp with a Vidar and was thinking about just trying it out. Using all SE of course.
Volume knob aside, I'm still very much enthralled with this amp. I don't know what it is about it but there's just something that sets it apart from the others I have in use. It's almost the same experience when I finally bought a Stax system. Just a different "sound" altogether from what I've been listening to. I'm also seeing quite a bit of chatter about upgrading the 12AT7 tubes. It would be worth the $100-150 to find out if it makes it even better.
Spent a lot of time with Sennheiser HD 660S and Focal Elears since my original post. They both sounded faaaaaantastic. The Grado GS1000e on the other hand, not so much. Although they've been hit or miss over the years, mostly miss, and I only use them for jazz because any other genre with them is awful. Same goes for the 600 ohm DT990. Greatest pairing I've ever heard with this amp, but they only sound good with classical. Especially strings.
Rant over. For now.
Upgrade the 12AT7 tube? For sure, but don't stop there. The stock tubes are OK but you can improve on both sets.
Over two years with this amp and it still brings a smile every time it is powered up. Experiment and enjoy.
gonzalo05
- Sep 20, 2015
Are you using the C8 as a pre?Proper preamp? Yes, and run the MHA200 at 12 as designed.
Yes, with the DA2 DAC option. Very flexible and I mix it up with several other headphone amps for fun.Are you using the C8 as a pre?
gonzalo05
- Sep 20, 2015
How's the headphone output on the c8?Yes, with the DA2 DAC option. Very flexible and I mix it up with several other headphone amps for fun.
Only tried it a few times when I got the C8 about two years ago. Didn't give it much time. It isn't bad but it isn't likely to satisfy a headphone fanatic. More of a convenience feature for a normal McIntosh consumer whomever that might be.How's the headphone output on the c8?
scfsanfran
So with my set up with the MHA200, my RME ADI Pro SE dac and my 2022 Utopias, can someone recommend tube upgrades for this combo where the Utopias will shine best?Thanks very much!
I switch the Mullard 12at7 instead of the original JJ and the result is quite positive!
2K9R56S
Went round and round deciding between a Freya+ or Kara, then went in the opposite direction and gave the Emotiva XDA-3 DAC/Preamp a whirl. I think it's a keeper. It sounds more Yggdrasil-ish than the squeaky clean and precise sound of the Benchmark. And it only took a few minutes to be spoiled rotten by the volume buttons on the remote control. The MHA200 is set at 3 o'clock sharp for extra stank. High noon was nowhere near enough. AND the XDA-3 will match nicely with the Emotiva ERC-4 that I bought and forgot about.
Updated. Grabbed the ERC from storage. Using the balanced out from the ERC instead of using it as a transport.
Still amazed by the MHA200 out of the box.
NoTimeFor
- Jan 10, 2017
Anyone use mha200 with dca expanse?
Total: 6 (members: 0, guests: 6)
