So the SU-1 does support native mode DSD. That's good to hear. AES/EBU, Coax, and Optical are the same supported sample rates as the X-Sabre Pro. That is simply the limitations of the spdif protocol.
The X-Sabre Pro does support PCM 32/768 via USB. Just limited to DSD 512 on the USB input. The SU-1 should be able to handle 32/768 with ease using the XU208 and also add DSD 1024. As long as Singer is using a really good clock these other rates should be possible with just a firmware update. I know the new XMOS chip is surely capable of it.
I have toyed with picking up a Singer SU-1 to play with but I'm not sure what the benefit would be until they enable the full capabilities. Again having the USB conversation done outside with it's own power supply is intriguing and may have some additional benefits.
I would really love to see someone make a thunderbolt interface to I2S. That would be the equivalent of a PCIe card with a direct connection to the PCI express lanes but in an external isolated box with its own power supply. Thunderbolt 3 in via a USB C cable and I2S out via a HDMI cable. Then things could get really interesting. No USB conversion in the path!
