SolaVirtus
The power supply is 24v, 1.8A.
Not sure about the plug size and polarity, I don't have that handy.
Oh I see because am thinking of adding lspuThe power supply is 24v, 1.8A.
No, we don't just use half the input signal. We use it all, through an instrumentation opamp differential input stage.
Both 789 input types are extremely high quality with impeccable measurements. For most setups, indistinguishable.
Choose the DAC you like best, and if you must use RCA use short cables 1-2ft. It'll be awesome. Cheers!
Hi I dont find the THX 789 volume knob scratchyHello All!
Question, How would one go about removing the Volume Knob? This scratchy volume pot needs to be replaced.
Mine is.Hi I dont find the THX 789 volume knob scratchy
No, would be the same. Probably the number game that would be different but no audible difference for sure.Has anyone moved from a THX 789 to a SMSL SH9?
The 789 is one of the few amps that surprises me. I was wondering if the SH9 would be more of the same great thing.
Probably yours is quality control or due to age. Its actually suppose to be buttery smooth when you rotate the knob. The power button is definitely scratchy when you press them but thats original factory condition as brand new. Overall, I still like the unit itself.Mine is.
They will sound the same.I think that if I did order the SH-9 I would find it the same or worse and be somehow disappointed. There are a few reviewers that say it comes close to the HPA4, which I have heard.
If the SH-9 goes on sale or Drop I may get it.
Hello I thought people say THX 789 and Arya not a good pairing, something about sounding too bright no ? I dont see the dac pairing with 789I haven't used my 789 for ages, so dug it out this morning and have to say it sounds fantastic!
It doesn't sound bright to me?!Hello I thought people say THX 789 and Arya not a good pairing, something about sounding too bright no ? I dont see the dac pairing with 789![]()
