Superpong
- Aug 2, 2007
I currently use and enjoy listening my Cavalli Carbon X but I am looking for another amp with more power. Overall, is this THX AAA 789 better than Carbon X?
Spec wise the 789 is better, but if you like the Cavalli sound I would stick with the Carbon. I run an AIRIST AUDIO R-2R DAC with my 789 to warm the sterile sound up to my liking. The 789 is great for hard to drive planar HP's and that is what I have plugged into it most of the time in balanced mode.I currently use and enjoy listening my Cavalli Carbon X but I am looking for another amp with more power. Overall, is this THX AAA 789 better than Carbon X?
This amp is really sterile i wonder why. I guess negative feedback is really harmful. Are there any good measuring amps with minimal negative feedback ? I know the Asgard 3 at high gain has low negative feedback but it's too loud for modern sensitive headphones.Spec wise the 789 is better, but if you like the Cavalli sound I would stick with the Carbon. I run an AIRIST AUDIO R-2R DAC with my 789 to warm the sterile sound up to my liking. The 789 is great for hard to drive planar HP's and that is what I have plugged into it most of the time in balanced mode.
..... to warm the sterile sound up to my liking....
No, not at all. Many describe it as an amplified wire, silent no noise or distortion, pretty much what goes in comes out louder.Would this mean that 789 is a bit bright?
Been really enjoying the 789 + tube amp fed from preamp outs. Very warm, bassy tone but with the 789 speed and precision. The tube amp is a little bit better in terms of soundstage but I forget all that after a few days with the 789 again.
I just ordered one of these. I have a Marantz HD-DAC1, and I'm curious how the 789 will sound with the Marantz as its DAC. The Marantz is a nice unit, but its sound is a little too warm for my taste through its headphone jack, and I'm guessing that the warm sound is due to its amp rather than to its DAC, since there is no warm tendency when the DAC output is feeding my AVR and speakers. I usually listen with Focal Clears, but I also have HD600's.
Which version of the HE-400i do you have? The original version had a backplate, and it sounded completely different from its successor, which had no backplate and had different connectors. That's the version I have, and I have never liked the distortion it adds to the midrange, especially evident on acoustic piano. Then there is the "2020 edition" HE-400i, which has a completely different build--haven't heard it.I just got the 789 for my DT1990 and He-400i.
If the Marantz has headphone + preamp / DAC out, the 789 will sound like the headphone outMy THX amp arrived today. Its source is the DAC in my Marantz HD-DAC1 (which is also a headphone amp). With Focal Clears, I am so far hearing little if any difference between these amps. I'll have time for more extensive listening tomorrow. I'll also see what differences show up with HD-600's, and I will also try the Clears with their balanced cable--although I don't expect any significant benefit to using it.
I own an older version of the 400i ( 3.5mm version ) as well as the 2020 version. I compared them both against each other on my THX AAA 789 and they sound the same as far as I can tell.Which version of the HE-400i do you have? The original version had a backplate, and it sounded completely different from its successor, which had no backplate and had different connectors. That's the version I have, and I have never liked the distortion it adds to the midrange, especially evident on acoustic piano. Then there is the "2020 edition" HE-400i, which has a completely different build--haven't heard it.
