Choose at least 70 watt transformer model
Massdrop x THX AAA™ 789 Linear Amplifier - Impressions Thread
- Thread starter XERO1
Teradak emailed me back and said that it would be a custom 24v LPS for $119,
I asked if it would be like this.https://www.teradak.com/products/97.html
Large case and toroidal transformer and they said yes.
Rated for 2A.
Rated for 2A.
HumdrumPenguin
I received the 789 on Monday and have been listening to my AEON 2 CB through it since then, using the 1/4 jack. It's connected directly to the iMac 2019 I use at the office, so it's using the mac's internal DAC. I can't hear distortion, hum, or background noise AT ALL, even if I put the gain at the third mark, volume pot at max, and have no music playing (which I can't say the same for my Asgard 3). Now here's the question, will an external DAC make any difference? I'm not thinking of the features it may have to offer, such as DSD, MQA, filters, remote control, etc. If the answer is no, the sound will be the same, then I'll save money to buy a full feature standalone DAC a few months from now (SMSL SU-8S / 9 when it releases, for instance).
If there are improvements to be heard still, I'd now get a Topping D10 or D50s, or SMSL M100 / M300 and settle on it for a while.
Also, since the output is not balanced on the 789, would I benefit at all from connecting my cans via balanced XLR cables aside from higher volume?
geoffalter11
Short answer, Yes! DAC will make a difference. However, when you do it should based on what you want. I personally feel you should buy the best you can afford at the time you are ready. If you are satisfied for now, wait and get what you want when you can. But, yes I believe an external DAC will greatly improve your system. Whether you go with a delta sigma or an R2R depends on what your sonic preferences are. I like the R2R sound, especially with my 789 as it is such a clean amp. I like the added warmth and smoothness of provides while still extracting plenty of detail. To me there is no wrong DAC.I received the 789 on Monday and have been listening to my AEON 2 CB through it since then, using the 1/4 jack. It's connected directly to the iMac 2019 I use at the office, so it's using the mac's internal DAC. I can't hear distortion, hum, or background noise AT ALL, even if I put the gain at the third mark, volume pot at max, and have no music playing (which I can't say the same for my Asgard 3). Now here's the question, will an external DAC make any difference? I'm not thinking of the features it may have to offer, such as DSD, MQA, filters, remote control, etc. If the answer is no, the sound will be the same, then I'll save money to buy a full feature standalone DAC a few months from now (SMSL SU-8S / 9 when it releases, for instance).
I've heard a couple rough ones in my day. I don't see many people liking some of the old soundblaster cards, those were terrible. Then again you are right.. somebody liked it enough to make and sell the thing.Short answer, Yes! DAC will make a difference. However, when you do it should based on what you want. I personally feel you should buy the best you can afford at the time you are ready. If you are satisfied for now, wait and get what you want when you can. But, yes I believe an external DAC will greatly improve your system. Whether you go with a delta sigma or an R2R depends on what your sonic preferences are. I like the R2R sound, especially with my 789 as it is such a clean amp. I like the added warmth and smoothness of provides while still extracting plenty of detail. To me there is no wrong DAC.
geoffalter11
Haha... so correct. I find the DAC I use to be a huge part of the chain. Most DACs today in that $200-$300 range will get you something way better than a MACs internal DAC. I use an iMac running Roon and don't love the internal DAC.I've heard a couple rough ones in my day. I don't see many people liking some of the old soundblaster cards, those were terrible. Then again you are right.. somebody liked it enough to make and sell the thing.
HumdrumPenguin
Would you mind recommending a few on that price range? Ideally balanced if the price allows.
geoffalter11
Yes. Most of my experience has been with DACs in the $1000-$1500 range. But, I would consider the following.Would you mind recommending a few on that price range? Ideally balanced if the price allows.
1. ifi Zen
2. SMSL SU-8
3. Geshelli Labs Products
4. Schiit Modi Multi Bit - don't think it comes balanced
5. Airist R2R DAC - not sure if balanced. But a great DAC for the price. You'd need to find a used one.
- Sep 28, 2016
Get the d50s first, then save for something better, I recommend the rme adi2 DAC. Balanced input does not matter with short runs of cable unless you have a ground loop. In fact, the engineers of the amp recommend RCA unless you need the noise rejection of XLR (noise loop, EMI etc). Plugging your headphones into the balanced jack in the front is a whole different thing though, way more power for you cans is always a good thingI received the 789 on Monday and have been listening to my AEON 2 CB through it since then, using the 1/4 jack. It's connected directly to the iMac 2019 I use at the office, so it's using the mac's internal DAC. I can't hear distortion, hum, or background noise AT ALL, even if I put the gain at the third mark, volume pot at max, and have no music playing (which I can't say the same for my Asgard 3). Now here's the question, will an external DAC make any difference? I'm not thinking of the features it may have to offer, such as DSD, MQA, filters, remote control, etc. If the answer is no, the sound will be the same, then I'll save money to buy a full feature standalone DAC a few months from now (SMSL SU-8S / 9 when it releases, for instance).
HumdrumPenguin
Thanks, I'll already have looked at all of them. The Geshelli would be great if it worked via usb. The mac doesn't have digital out. The RME ADI 2 DAC looks great, but totally out of my budget, unless I find a used one in good conditions for a good price. So dard to decide...
geoffalter11
RME is an R2R. It is insanely good. If you want that type get a Metrum Flint.Get the d50s first, then save for something better, I recommend the rme adi2 DAC. Balanced input does not matter with short runs of cable unless you have a ground loop. In fact, the engineers of the amp recommend RCA unless you need the noise rejection of XLR (noise loop, EMI etc). Plugging your headphones into the balanced jack in the front is a whole different thing though, way more power for you cans is always a good thing
- Sep 28, 2016
D50s. Affordable, measures well, sounds good too.Thanks, I'll already have looked at all of them. The Geshelli would be great if it worked via usb. The mac doesn't have digital out. The RME ADI 2 DAC looks great, but totally out of my budget, unless I find a used one in good conditions for a good price. So dard to decide...
HumdrumPenguin
Doesn't have usb. I need it.
I think RME ADI2 uses an off the shelf DAC part like 4490 and recently upgraded since that part is end of life.
