PeteMtl
- Aug 19, 2014
Being fairly new to the head fi community, and relatively green when it comes to headphones, Sennheiser has done a wonderful job of confusing the heck out of me. That being said, out of all the 600 series, I'm fairly confident the 660s is the one I want. I just stumbled across this thread, and had no idea the HD58X even existed. Without reading every single post in this thread (I read the 1st post from the OP), does the HD58X closest resemble the 660s? If this is the case, I definitely need this set of cans. I don't think I've even come across these for sale in the classifieds or ebay. Is this drop going to go live again, or is it over? If this set of cans closest resembles the 660s (same drivers?), why does it have a 500 series name? Somebody please tell me these are closest to the 660s for less than half of the retail price, and then tell me you have a pair for sale! !
1. The HD58x is not the same headphone as the HD660S. It does not use the same drivers. However, it’s the closest to the HD660S without being the exact same. Both have the same impedance. The drivers are not equal but their technology and design are related and similar. The sound signature is very similar if we take into consideration the recently released graphs of the production version of the HD58x. From around 100hz and above both headphones are quite similar, with raised response around 1khz, dip in the 2-3 kHz region and rise around 7-8 kHz. All of this is quite similar between the two. The bass however on the production version of the HD58x is more extended and higher in the sub 100hz area all the way down to 20hz. So we should expect the HD660S to have a lighter cleaner bass, and the HD58x to have a thicker sub bass. But in the end almost nobody heard the production version of the HD58x just yet, so all of this is inference on the recently published graphs. Another difference is the pricing: 149$ for the Hd58x and 499$ for the Hd660S...
2. The HD58x Jubilee name is a blink to the original Sennheiser HD580 Jubilee, which evolved later as the HD600, which later on produced derivatives such as the HD650 and 660S. So the HD580 was in fact the genesis of the 600 series Sennheiser. Therefore the HD58x Jubilee simply borrows its name from the original HD580 and is therefore a true 600 series headphone, do not worry. The latest 600 series headphones, HD660S and HD58x, use 150 ohms drivers instead of 300 ohms drivers used in all other 600 series since the original HD580.
Therefore apart for the sub bass response I expect both headphones (58x and 660S) to sound in a similar way without being identical twins...
