Great headphones for gaming!
Massdrop x Sennheiser HD 58X Jubilee Review & Measurements
- Thread starter jude
Another dumb question:
How hard am I supposed to pinch the cable while pulling it out? Will it damage it if I don't pinch it hard enough while pulling it out?
Thanks in advance!
Thanks in advance!
All my cables have a molded portion at the top, so I'm not sure what you are pinching. Keep hold of that and not the cable and it should pull straight down and out.Another dumb question:
Thanks in advance!
Thanks, got a bit confused from this videoAll my cables have a molded portion at the top, so I'm not sure what you are pinching. Keep hold of that and not the cable and it should pull straight down and out.
I think you could substitute "grasp firmly" for "pinch" in that video. It's pretty easy most times - you might have to wiggle a little bit, but not too much or you might bend the pins.
Davidzak64
I had buyers remorse at first with the HD 58x's until I removed those damn foam pads in front of the driver. What a difference! They came alive. I'll be doing the curtain mod also. Now they have that high end sparkle these old ears desire. I prefered the sound of the HD-598'S better before removing the foam from the HD 58x's Jubilee's.I would agree it is very versatile but have to say perform the curtain mod (look it up here on Head-Fi and on internet in general, it's easily found) and they become great for music and movies! Haven't tried it gaming admittedly. I much prefer the 58X (especially after curtain mod) to the other cans in the 5XX family (not counting 580 as they are in the 600 family).
That's great to hear! Let us know what you think after the curtain mod.I had buyers remorse at first with the HD 58x's until I removed those damn foam pads in front of the driver. What a difference! They came alive. I'll be doing the curtain mod also. It has the high end sparkle these old ears desire. I prefered the sound HD-598'S better before removing the foam from the HD 58x's Jubilee's.
I had buyers remorse at first with the HD 58x's until I removed those damn foam pads in front of the driver. What a difference! They came alive. I'll be doing the curtain mod also. It has the high end sparkle these old ears desire. I prefered the sound of the HD-598'S better before removing the foam from the HD 58x's Jubilee's.
what is it like not having as much highs? Some of the older guys I work with drop off after 6k but the graph only goes up to 8k
Why do certain people in this thread consider the HD58x part of the 5 series? Every review I have read says it is part of the 6 series as it was based on the HD580, which is part of the 6 series as well. It uses the same housing and parts as all the other 6 series too!
It's the most affordable 6 series Headphone.
Nothing to do with the 5 series.
Maybe it is the name that misguides.
Davidzak64
I'm talking 10-20 Khz area being non existant before removing the material.what is it like not having as much highs? Some of the older guys I work with drop off after 6k but the graph only goes up to 8k
It bumbed that range up a couple of db. My hearing is okay but up to around 17 kHz.
It was like listening to the oceans waves with your hands slighly covering your ears is the best I could describe. Highs were muffled.
Davidzak64
I definitely will report back. Right now after removing the foam my EQ settings look like this. I'm hoping for more of a flat curve after the curtain mod but they sound great right now.That's great to hear! Let us know what you think after the curtain mod.
eeagle
Yes the parts are similar to the HG6xx series. It is not based on the HD580 which was an all plastic version of the HD600, both having the same 300 ohm driver.Why do certain people in this thread consider the HD58x part of the 5 series? Every review I have read says it is part of the 6 series as it was based on the HD580, which is part of the 6 series as well. It uses the same housing and parts as all the other 6 series too!
The HD58x is closest to the HD660s, both of which have a 150 ohm driver....reviews vary as to which sounds the best, but one can sure save some $ w/HD58x.
TrixRabbit
I've had my 58x for about a month now and absolutely love them! I use them between 4 to 10 hours a day if I have the free time for gaming, movies and a ton of music, including; classical, rap/hiphop, old punk and metal, electronica and pop. The great thing I found with them, is that even poorly mastered music or old stuff thats just bad quality still sounds great on them. FLAC or 320k music on them really stands out for clarity and crispness, and they feel really "alive" and "energetic/energized" listening to music. Gaming on them is VERY enjoyable and the insane amount of details and imaging is out of this world, especially on intense games like BFV.
I've set up Foobar2000 with a metric crap ton of music, and now enjoy them even more with just massive playlists of various genres autoplaying throughout the day.
Thanks for helping me choose the 58x and also recommending Foobar2000. I have zero urge to want any other headphones, nor do I even want to EQ them or mod them in any way.
Total: 8 (members: 0, guests: 8)
