Recently been experimenting with something called fo.q ta102 tape. Used it to modify my Sony Z7m2 with phenomenal results so I thought I'd try it on my other headphones.
Just a little background info on this material from the manufacturer. "‘fo.Q’ is a product applying materials developed with the support of JST (Japan Science and Technology Agency). Vibrational energy is converted to electric energy, and finally to heat energy, enabling efficient absorption. There are no rubber or heavy metal overtones, and efficient attenuation of the finest vibrations, considered difficult to remove up to now, promise you the purest and clearest tones"
It is not cheap at about $50-60 ordered from Japan. I know it seems ridiculous that such a thing could produce such drastic results. I was skeptical when someone recommended this but after seeing what it did to improve my Sonys, I had some left over and wanted to see it could do with the 58x.
There are quite alot of changes, the graininess in the upper mids/lower treble around 3-4k is about 90% removed, there is an increase in clarity, detail, soundstage, imaging. Bass is about the same but cleaner and tighter with better texture and detail. Basically, it becomes a better version of itself.
