PeteMtl
- Aug 19, 2014
Thanks for the reply!
Few things worries me:
1. Will my Marantz + Dac be good enough for HD6xx
- I don't have money for dedicated amp
2. Bass on HD6xx
- I had HD598 and they were lacking bass
- I'm not bass head but on HD589 bass had no impact at all
- so bass on HD6xx worries me
1. Marantz: what exactly is your Marantz amping setup? Normally, regular speaker amps (stereo or multichannel receivers, integrated amps) are not well suited for headphones, because their output impedance is too high and don’t respect the 1/8 rule (output impedance of amp shouldn’t exceed 1/8 of the impedance of the headphone). Most receivers I know including my Onkyo receivers have a headphone output impedance of over 390 ohms and the impedance of the senns are 300 ohms (hd6xx) and 150 ohms (hd58x). You will still be able to use your receiver’s headphone out, but the sound will be muffled, bass will not be clear and firm, but rather muffled and loose because of the impedance mismatch. These amps simply use the main amping used for speakers and apply a strong impedance in order to bring down the power to headphone levels instead of using a dedicated separate headphone amp section such as small op. amps on integrated circuits. Some stereo receivers or integrated amps may provide a dedicated headphone amp section that is independant from the main speaker amping section, but I have very rarely seen it is the case. On the other hand amps like the O2 or the Schiit Magni 3, which both can be had for 100$, have an output impedance specification of under 1 ohms, therefore well suited for any headphone with impedance of 8 ohms or more (most headphones have an impedance between 18 ohms and 600 ohms depending on their design), therefore they may drive well any headphones.
As I told you the HD58x doesn’t need an amp and may be driven directly from the output of a computer, iPhone, iPad, but would benefit eventually from a dedicated amp such as the Schiit Magni 3 or O2 from JDS Labs or Massdrop. The HD6xx would still be usable with a portable, but would only play at very moderate levels because they require at least 2v of output voltage to really shine and most computers or portable devices will not output over 1V, some of them even less than 1v. My iPhone and iPad may output at close to 1V and my mac outputs up to 1.25v I think, enough for the HD58x and a bit short for the hd6xx. And all of these portable gears have headphone jacks or adapters, although with low voltage output, provide very low impedance output, most under 1 ohms, thus perfect for driving most headphones that require low voltage amping. By comparison the O2 and Magni3 at 100$ may output at over 5 or 6v and also have very low impedance output, under 1 ohms typically. Both headphones are quite efficient and do not need a lot of power to be driven to high levels, but they need voltage, at least minimally 2v for the HD6xx and a bit less for the HD58x. So any decent small dedicated headphone amp with low impedance output that may produce at least 2v of output should do it. I think my hd6xx doesn’t need more than a few mW of power (Volts x current = watts), maybe 20 mw is more than enough, (although audio purists will argue that you need 10x that power for peaks power and snake oil argumentation....). I say to you that both of these headphone don’t really need that much total power, they are very efficient, but the HD6xx need higher voltage than what most computers and portables may provide.
2. I also own the HD598 and I too believe it doesn't have enough strong deep bass. I use them solely for TV usage because of their relatively low impedance. I may assure you that the HD6xx has far better and stronger warmer bass than the HD598, it is not comparable. The HD58x has even deeper bass than HD6xx and it is its strong relative advantage compared to the HD6xx. I find however than the HD6xx is more natural, warmer, more romantic and I prefer the mids of the HD6xx over the hd58x. That is why I prefer the HD6xx over the HD58x, except with music that has a lot of sub bass such as electro music and deep house. But overall all HD6 series of headphones have far better bass than HD5 series in my opinion, with the HD600 that has the least bass of the HD6 series and the HD58x that has the deepest sub bass response (35 hz to 100 hz) of the series. The HD6xx has a bit less of sub bass but has a bit more higher bass accentuation (mostly in the 100hz-250hz region) which gives them a warmer rounder sound. Hope it helps, hope I wasn’t too technical.
