highlightshadow
You turned down the pre-gain so it's not clipping? The EQ is based around a V shaped response, the Harmon Curve, which is based on what you would hear from monitors in a high end recording studio. The standard for headphone tuning (i.e. any time a graph says "compensated response") for many decades has been the diffuse field curve, Arguably an inferior and unrealistic way to measure response. Whether you like that or not is preference tho.
I would set a second EQ preset in EQ APO/ Peace that is the same overall volume as your tuned EQ, that way you can A/B them without having to adjust the volume.
On a side note, I had to turn pregain down to -7db to avoid clipping on some tracks, even tho the settings from oratory1990 say it should be -5.7db.
I found that setting a high shelf filter somewhere between 1khz and 3khz with a -1db to -2db pad helps with the shrillness and dropping the original low shelf filter from 6db to 4 or 5db is easier to listen to.
It's fun to play around with and see what sounds good. Even without a tuned EQ, I like to use a -3.5db pad on pregain to avoid clipping from loud tracks, and I like to use a highpass and lowpass (.8Q) on either end to remove any ultrasonic or subsonic noise.
Could you post your peace preset file obyo Google drive or Dropbox. Be nice to compare.
Thanks
