I've been using mine with the Dekoni fenestrated sheepskin pads for some time and I think they sound exquisite with these pads onAre there any good alternatives for new Elex pads? The Dekoni Velour are comfy enough but the sound isn't quite as good as with Elex/Clear pads.
Massdrop x Focal Elex Review & Measurements
- Thread starter jude
Shane D
I wonder how the Dekoni fenestrated sheepskin would sound? I have no idea, personally.Are there any good alternatives for new Elex pads? The Dekoni Velour are comfy enough but the sound isn't quite as good as with Elex/Clear pads.
b0lt 0ns
Dekoni fenestrated sound awesome on elex. They increase the bass/slam. In my opinion it's what they should come with from the start. They're also more comfortable IMO.
jonathan c
On a related note, I have used those Dekonis on Focal Clear OG for > 2-1/2 years. Sound: just as you say + airy midrange/treble + wider soundstage. Easy to clean !!Dekoni fenestrated sound awesome on elex. They increase the bass/slam. In my opinion it's what they should come with from the start. They're also more comfortable IMO.
Shane D
Does it affect the bass? Do you lose anything from stock?On a related note, I have used those Dekonis on Focal Clear OG for > 2-1/2 years. Sound: just as you say + airy midrange/treble + wider soundstage. Easy to clean !!
You lose a tiny bit up top, the suede material is better at accentuating the treble.Does it affect the bass? Do you lose anything from stock?
Its a trade off, you get alot more hardhitting bass and richer mids but lose a small bit of resolution and articulation in the higher frequencies.
b0lt 0ns
They sounded awesome earlier today on a nice little WA6SE that some guy sold me for a deal with a Sophia princess and a pair of Sylvania 13DE7sOn a related note, I have used those Dekonis on Focal Clear OG for > 2-1/2 years. Sound: just as you say + airy midrange/treble + wider soundstage. Easy to clean !!
jonathan c
To me, the bass is extended and more linear. Further up the frequency spectrum, I feel that nothing is lost but more air / wider soundstage is had.Does it affect the bass? Do you lose anything from stock?
Do they retain the airy soundstage? The velour I find narrowed it down and even made some frequencies sound distortedI've been using mine with the Dekoni fenestrated sheepskin pads for some time and I think they sound exquisite with these pads on
jonathan c
Probably because the velour are more absorptive than the sheepskin and are not fenestrated (perforated).Do they retain the airy soundstage? The velour I find narrowed it down and even made some frequencies sound distorted
Yes that makes sense.Probably because the velour are more absorptive than the sheepskin and are not fenestrated (perforated).
I'm planning on picking up the Elegia and think the velour could be more suitable as a spare pad for them as they're closed and stock pads are also cloth.
I'm going to try the cheap fenestrated cloth pads from China before going with sheepskin. I love the Elex sound so much I wish focal sold spare parts so I could keep the stock sound forever.
Plieb
The velour definitely were inferior with the elex. Totally deadened the sound. Zero sparkle. But more concerning was the fact that the plastic ring on one of the pads was not evenly centered and the left right balance was impacted.Do they retain the airy soundstage? The velour I find narrowed it down and even made some frequencies sound distorted
b0lt 0ns
Drop sells the stock focal branded elex pads. Go on their site and look under headphone accessories. They're on back order but they will come back in stock at some point.Yes that makes sense.
still have quality problems, death of the driver?
b0lt 0ns
My first set I ordered in June came with a dead left driver. The replacement set has been flawless with the exception of clipping at higher volumes.still have quality problems, death of the driver?
