Martin Logan Mikros 90 On-Ear Headphones
- Thread starter Speakerphile
H T T
- May 11, 2013
Mikros 900? No, you must mean...
... Mikros 9,000,000!!!
(♡´艸`)
chailee80
- Jun 8, 2013
Played around with some more pads today. Put the hd25 pads on then put some turtle beach px22 pads over those and was surprised that it very comfy and also sounded half decent. The px22 pads are a little loose fitting but bass response wasn't too bad the only issue is things sound a little distant due to the driver being quite far from my ear. Now to see if i can fix those 2 problems
pataburd
Do the HD-25 pads fit over/around the earcup rim after removal of the stock pads?
Maybe a moot point for me, since I already like the stock pads and their fit.
chailee80
- Jun 8, 2013
Yep they fit quite easily over the mikros 90 earcups.
pataburd
Anybody willing to give this cable a try?
The 5.6mm barrel diameter on the input side should fit the Mikros 90 (whose recess hole is 6.5 mm, I believe).
http://www.amazon.com/Replacement-upgrade-skullcandy-crusher-headphone/dp/B00OQWV9J4/ref=sr_1_13?s=electronics&ie=UTF8&qid=1414354373&sr=1-13&keywords=nad+headphones
pataburd
Maybe I'll try the HD-25 pads on my "least favorite" pair of Mikros 90, the treble-heavy/bass-light ones.
pataburd
ANYBODY OUT THERE?!?!?!
Looks like a well-constructed cable. No information on the actual wire used though, at least not on Amazon.
Who's is gonna take this one for the TEAM?!?!?!
Trunks159
- Aug 2, 2012
Stop modding them! They're basically all machine at this point .
Lorspeaker
- Nov 29, 2010
mine is all stock....cept the innards
Trunks159
- Aug 2, 2012
nick n
- Feb 3, 2011
waynesworld will be getting a vastly improved version of the mod I did in the next couple days. Bring on that feedback Mr Wayne!
PLUS Possibly another member here who also has the exact same materials , also, possibly, hopefully.
Here's how I basically described them now ( minus the embellishments ).
"Smoothed out clean sound, tight bass and peaks without shrill rash on your eardrums, and not too smooth or muffly + great space".
Been on my head for over an hour now and counting.
YESSSIR!
if it's any good I will update ( heck if it's any good... these are damn great. )
But that's just me.
YESSSIR!
waynes world
- Jun 21, 2012
Can't wait to receive them nickerfied 90's Nick!
Lorspeaker
- Nov 29, 2010
To get the kind of sound mikros is producing...
The can tat comes to mind is the pandora6
geobrick
- Jan 15, 2012
<Update: This deal is over.>
Newegg has the Mikros 90's for $60 again.
Available from 10:00AM - 12:59PM PT 11/01/2014
That's 10AM to 1 PM -1 Pacific Time.
Here's the newegg link to their Shell Shocker page: http://www.newegg.com/Special/ShellShocker.aspx?nm_mc=EMC-SD112014&cm_mmc=EMC-SD112014-_-SD110114&utm_medium=Email-_-item-_-26-532-001&et_cid=12627&et_rid=18306&et_p1=
If you missed the last 15 to 20 times they've been at this price, now's your chance.
