--- Well I have had 3 hours with the OPPO. First, the build quality is amazing. Hell of a piece of gear. UI takes a minute to understand and configure but makes up for that with the cool VU/EQ meters (must stop watching them). What a contrast between the OPPO and Marantz, the OPPO being very modern in all black with the active display and the Marantz with the wood panels and small "Marantz" circular window. Two different takes by the manufacturers for sure.
This is not a final impression: The OPPO as a preamp running my two-channel setup is superior to the Marantz. Better staging, more width, crisper more detailed upper-mids and crystal clear treble. I like it more as a stereo piece. Also having BT built-in is handy when I dont want to get off the chair and change music. Nice!
This is where is becomes a little clouded for me. The OPPO has plenty of HP power single-ended but I have to crank the volume to 2 or 3 or even 4 o'clock to get to a level where I can rock out. In contrast, the Marantz, in high gain, does not need that extra twist of the wrist to blow my head off. Both don't distort, I want to make that clear, but for some reason I think the HD-DAC1 has more juice. The specs don't say so, I'll have to listen more.
Another thing I like about the OPPO is that USB or another input stays locked, whereas, the marantz will click out of lock until it gets a signal, sometimes even between tracks!
I am inclined to keep the OPPO just for its other uses in my system but I will hold off for a few more days.
Alright, back to downloading freebie DSD files.
