mmoraw
- Oct 19, 2011
I got both AKG K7xx and HD800, and can only say that's both sounds fantastic,
Anyone else experience the DAC1 relais switching when manual switching songs or pausing in foobar. I´m using wasapi output and tried others . This is especially annoying when you only have Window sounds and the DAC1 is switching on and off, when you change the Folder.
I talked to Marantz and in their opinion this may be a faulty device. But reading around the internet, other experience the switching orgy of DAC1, too.
What is your experience with the DAC1? Are you concerned about reliability of the Device, if it switches that often?
@alllala Its normal, evertime you change or seek track usb starts to clicking.
You can avoid this in foobar by turning on fading, look at mine setup
Electrical relays used in electronics have a mean time before failure measured in the 10's and 100's of millions of cycles so not likely to be a failure point in this unit unless they were faulty from brand new.
My HD 700 cans arrived about an hour ago. I plugged those babies in and fired up Tidal. OH MY GOODNESS I am really going to enjoy these headphones. I imagine they will sound even better as they break in, but it sounds pretty amazing now.
Anyone have any suggestions on where the gain should be set on the Marantz for these phones? Thanks
Good evening
I have been looking into picking up a new dac and the dac1 is on my list. You all still feel it's a good dac. Mainly would use optical from cd transport network streaming but some usb.
How do you all think it would compare to rega dac1, music hall 25.3, pro ject dac box rs?
Thanks
If you don't need a excellent HP amp but just a dac, then you should look into some other options, too...
IMHO, the Hd-DAC1 excells as a combo, due to its headpone amp ... As a dac, after some comparative listening with 4-5 contenders, I found that is relatively not so trasparent, and the sounstage lacks the dimensions of other machines.
I didn't hear the ones that you mention.... In the same price range, I believe that Pioneer UD-05 is a far better dac. However, as a combo, Marantz is the winner since its amp is so much better and powerful compared with the Pio's ...
